Solid steel trem block in maple body "Strat"
Discussion in 'Stratocaster Discussion Forum' started by kiwi blue, Nov 15, 2019.
  1. kiwi blue
    kiwi blue Tele-Afflicted
    Wellington, New Zealand
    Hiya.
    Posting here because Stratty folk know a thing or two about trem bridges.
    I have a Westone Spectrum, a Matsumoko guitar from the 80s. Is it a Strat? Kind of. But not really. It's HH configuration, with maple body and neck and a 2 point trem bridge that's based on the Fender Strat bridge but again different.
    The neck is wonderful. I like the bridge bucker and I've upgraded the neck pickup to a rod magnet P90 style in HB size. Overall the sound is good but on the thin side with a high end brittleness that's hard to get rid of. This is also clearly audible in the unplugged sound. On the positive side the guitar sounds very clear, and the bass notes are tight and also super clear. This lends itself to fingerpicking and jangly sounds.
    Pretty sure the maple body is mainly responsible for this, but the trem block is a puny zinc block.
    Today I bought a Hipshot 6 point trem bridge in a close out sale. I'm thinking a solid steel bridge might help give the guitar a more balanced sound, but also there's no getting away from all that maple.
    What do you guys think? I can still change my mind and use the Hipshot in another guitar.
    Greggorios likes this.
  2. mkdaws32
    mkdaws32 Tele-Holic Silver Supporter
    Moncton, NB Canada
    I know compared to brass, steel is brighter - I don’t know about zinc. I would think the saddles would make a larger difference on tone than the block itself - but it’s just a guess. Chrome covered brass saddles on the existing bridge might warm it up some.
  3. tele12
    tele12 Friend of Leo's
    NY
    I always put a steel block in. All of the Pre-CBS Strats had a steel block, CBS changed to zinc, and all the cheap Strat copies come with a small zinc block.
    Will it get rid of the brightness? I haven't noticed drastic changes in the tonal balance when I have changed block.
    What I have heard is greater sustain and clarity and note separation.
    So I don't know if this ccx will give you what you want, but I would have to try.
    I have read brass mellows the tone out but haven't tried a brass block.
    Greggorios and Dismalhead like this.
  4. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Tip the pickup E vs e side.
    Lower both pickups to the trim rings, raise the bridge until volume parity with the neck.
    Swap pots & caps.
    It's not the block.
    8trackmind and Greggorios like this.
  5. Dismalhead
    Sacramento, California
    I've made a couple of lightweight Strats and put a steel block in one and a brass block in the other. Main reason was to balance the weight in the guitars, but I do think a heavy block helps 'cause both really sing. It's a cheap upgrade too.
    tele12 and Greggorios like this.
  6. tfarny
    tfarny Friend of Leo's
    Hudson Valley, NY
    IF the tonal balance changes at all, I'd predict the steel block will make it brighter if anything. Adjust your pickup heights first, then explore brass saddles.
    I am always curious, though - you are happy with the sound of the pickups, but unhappy with the sound of the guitar? How does that work?
    Dismalhead and Greggorios like this.
  7. Mahogany
    Mahogany Tele-Meister
    XYZ
    Some of it is.
    Try one made of pre-WWI Bessemer cast steel.
    Or pre-atomic steel if you cannot get the above.
  8. schmee
    I think you were right; ".....but also there's no getting away from all that maple."
  9. Zepfan
    Zepfan Poster Extraordinaire
    Horn Lake, MS
    Steel blocks have always made my Strat types brighter, makes the harmonics more noticeable. So I would be going with a brass block or Aluminum barrel saddles if you can find them.
  10. skradlee
    skradlee TDPRI Member
    tempe
    I like brass blocks and saddles on my strats, but that is just my preference.
  11. L.A. Mike
    L.A. Mike Tele-Afflicted
    somewhere over a rainbow (Ex-L.A. resident)
    I'd make sure it has 500K pots and .022uf caps (tone control).
    Make sure it doesn't have a treble roll off cap on the volume pot.
    Make sure it's been wired correctly. Since it's from the 80s, people have most likely been in there.
    Check the pickup output with a volt ohm meter.
    Make sure the bridge pickup isn't too close to the strings. Since it's a bucker it doesn't need to be and if it is too close, lower it.
    Finally maple bodies are bright buy nature. That's why Gibson puts a maple cap on top of the mahogany bodied Les Pauls. Mahogany by itself can be a little dark sounding. That's why some Gibsons have 300k pots on solid mahogany bodied guitars.
    Zepfan and Greggorios like this.
  12. lost sailor
    lost sailor TDPRI Member
    No. Central PA
    +1 on pots and caps
  13. kiwi blue
    Thanks for all the thoughtful feedback.
    I should have mentioned that the guitar is left handed, which restricts some options (eg, a brass block).
    What I'm hearing is in the acoustic sound as well as plugged in. Some recent experiences with other guitars have led me to believe it's best to start by getting the guitar vibrating and resonating at its best before moving on to pickups and electronics.
    I don't have a problem with the guitar being bright. It's just there's a brittleness to the very high end that I want to tame, and also a sort of mildly scooped sound. If I can change that brittleness to chime and have a bit more body to the sound the guitar will go to the next level. The only thing left that I can do with regards to its acoustic sound is to do with the bridge.
    Just this morning I've spotted an alder Aria Pro II body (with no neck, electronics or hardware) that's also Matsumoko made and should fit my Westone neck. I now have this mad idea of buying that body and moving everything over to it.
  14. kiwi blue
    Pulled the bridge off today and noticed the block was painted black and where some paint had rubbed off it looked like brass underneath. It’s also non-magnetic which supports that. The bridge weighs 5 grams more than the Hipshot bridge. Can’t see any point replacing it now so back in it went.
  15. kiwi blue
    Now I have the guitar sounding much better. Decked the trem with 4 springs screwed in tight. I also experimented with damping the springs with paper towels. Both of these changed the sound surprisingly. I settled damping 2 springs and letting the other 2 ring.
    The guitar is still bright and clear sounding but that annoying brittleness has gone. I now think it was at least partly coming from the springs.
    The Manlius rod magnet p90 in the neck is loud and clear and dynamic. Great pickup.
    Zepfan likes this.
  16. richbike
    richbike TDPRI Member
    Brighton
    Ive got a spectrum st. Upgraded to a Wilkinson trem then upgraded the sintered steel block to a machined one.
    I think it's worth it but I like a bright chimey sound.
    Pups are custom made FWRH sort of copies wired in parallel.
    Controls a work in progress and hipshot staggered lockers literally ordered today.
  17. warrent
    warrent Friend of Leo's
    toronto
    And how does a few radionuclides added to the steel affect the sound?
  18. SixStringSlinger
    SixStringSlinger Friend of Leo's Silver Supporter
    Space
    Not sure if I missed this somewhere in the thread, but have you experimented with the trem cavity cover on vs. off? It may sound silly, but it may cure your "springs ringing too much" problem without need to resort to shoving paper towel in there (which will break down over time and create a mess, necessitating clean-up and replacement periodically).
  19. kiwi blue
    I haven't tried that, but the cover has been off the whole time. I did read recently where some people believe the cover creates a kind of reverb effect. I'll have to see if I can find the cover and experiment.
    The paper towels were just for proof of concept. I'll certainly replace them with something less perishable.
  20. MrGibbly
    MrGibbly Tele-Afflicted
    SATX
    I cut long thin square strips of that gray cushioning foam some products are packed in and pull it inside each of my trem springs. You want to make sure it is something that won’t cause the springs to bind if you use your trem.
