soldering pens
Discussion in 'Tele-Technical' started by oldteleguy, Sep 6, 2012.
  1. oldteleguy
    oldteleguy Tele-Afflicted
    wallingford,ct.
    Hi,does anyone here use a soldering pen instead of a soldering iron? I have old age issues:unsteady hands,artheritis,and diminishing vision,which make using a
    traditional iron difficult.Would the pen be better for me? if so,what model would
    you recommend?
    thanks
  2. sjtalon
    sjtalon Doctor of Teleocity Ad Free Member
    Upper Peninsula of Michigan
  3. soulman969
    Englewood, CO
    Another option if you have an O'Reilly Auto Parts store nearby although I'm sure others would stock them as well. This ones is about $6.00 and worked just fine for my last soldering job.
  4. TeleMan59
    TeleMan59 Tele-Meister
    Midwest
  5. LocustPlague
    LocustPlague Tele-Holic
    I was not aware that there was a difference between a soldering iron and a soldering pen. Could you please explain your perceived differences so that we can better suggest something to you?
    For me, the soldering iron and the soldering pen are the same. They are pen shaped devices, about screwdriver size, and usually have a plug on one end. I have also seen butane-fueled ones as well.
    The soldering gun is a trigger-style device that is usually used for larger jobs (read: REALLY REALLY big, like, never ever on a guitar kind of jobs).
    There are also those battery-powered "cold heat" or whatever bull**** things. I just call those garbage. I have one and got it to make 1 ("one") decent solder joint after messing with it for about 30 minutes. Not worth it.
  6. yellowbeard
    yellowbeard Tele-Holic
    florida
    I use an el cheapo iron I bought in radio shaft some years back. Not 100% sure but I think it's 30 watts. It works like a champ, even for soldiring ground wires to the back of pots. And FWIW, my hands shake, I can't see for crap, and the old joints ain't what they used to be either.
  7. mPetetele
    mPetetele Tele-Meister
    Hackettstown NJ
    I had a Radio Shack soldering iron-lasted about a week.Went to Sears and bought a Craftsman for under $25.00-great iron! and gets super hot! and my hands shake-at times.
  8. oldteleguy
    wallingford,ct.
    Yellowbeard-+1
  9. waparker4
    Philadelphia, PA
    Me too, never again; I couldnt finish my tele project last night. POS wouldn't even melt any solder
  10. Bartholomew3
    Bartholomew3 Friend of Leo's
    Montreal
    I also threw mine out - piece of useless junk. Would have returned it to the store but was 3 months before I tried it.
    Am using a 25 watt from Radio Scrap - works fine.
  11. jefrs
    jefrs Doctor of Teleocity
    Newbury, England
    The 45W Weller TCP = Temperature Controlled Pencil - is mightier than a pen
  12. Spaceboy
    Spaceboy Tele-Afflicted
    Richmond, VA
    I suggest getting a Hakko... best consumer irons on the market, IMO. Thin diameter grips, fine tips, awesome quality, heats quickly. I paid a bit under 100 bucks for my station but it's worth every penny. I got turned onto the brand through an old job we used some of the battery ones for industrial electrical work. I think the cheaper Hakkos run around 40 bucks, but may be cheaper now.
  13. Geo
    Geo Poster Extraordinaire
    Hendersonville, TN
    I have one like soulman969 shows and works well.
