Solder Wick Trick?
Discussion in 'Amp Tech Center' started by Ed Storer, Nov 23, 2018.
  1. Ed Storer
    Ed Storer Tele-Holic Silver Supporter
    Seattle WA
    I'm trying to remove a stupid PCB mounted input jack without much success. It's one of these.
    The chassis is folded above it, so I can't use a solder sucker. Solder wick can't seem to get the job done and I have to think it's my technique that's failing, not the solder wick. The product doesn't come with instructions and I'm hoping the TDPRI forum will give me direction on how to use the wick effectively.
    Edit to add images of the situation:
    Under-view:
    Thanks - Ed
  2. Old Tele man
    Old Tele man Friend of Leo's
    Once banned always banned
    Use a hand-held "solder sucker" basically a vacuum tube that literally "sucks" the molten solder from a joint/connection:
    Nickfl likes this.
  3. charlie chitlin
    Kimberton
    I put the wick right over the solder and put the iron on top of that.
    I think if I was worried about heat on pcb traces, I'd put some flux on the wick.
    Archtop Bill and jondanger like this.
  4. Formerblonde
    Formerblonde Tele-Meister
    Ottawa
    Never used a wick myself. ALWAYS used a solder sucker just like the one pictured above. If you're replacing the part then you can make the job easier by snipping the old component close to the solder lugs. Makes the cleanup much easier.
    You should always work from the solder side of the board and more often than not you end up regretting working on a pcb while it's still installed.
    Axis29 likes this.
  5. JL_LI
    JL_LI Friend of Leo's
    Long Island, NY
    You also may want to file a soldering tip to a gradually tapered point so you don’t disturb adjacent joints. Loosen soldered tabs one at a time lifting the jack gently as you go. It may take a few passes around the tabs to be able to remove it. It will be easier to wick or suck solder away once the jack is removed.
  6. Hobs
    Hobs Tele-Meister
    Nashville, TN
    Go ahead and remove that board from the chassis. Even once you get that desoldered, it's likelylik be difficult to replace the jack without damage where it is.
    DrBoBo likes this.
  7. galaxiex
    galaxiex Tele-Afflicted
    Edmonton, Alberta Canada
    Remove the entire board from the chassis. :eek:
    It can't be that hard.
    Yes, you will have to remove all the knobs and pot nuts... so what... techs do this kind of stuff all the time.
    I simply can't imagine that a tech would try to remove that jack with the board still in the chassis.
    If you don't care about the jack, cutting the pins with very small flush cutting snips make it a whole lot easier.
    If you are trying to save the jack, then it's a pain.
    Wally likes this.
  8. MrHamburger
    MrHamburger Tele-Holic
    Portlandia
    I would take angle cutters to the old jack then pull the lugs one by one.
    Then use a sucker like the one above to clear out the holes.
    I wouldn’t use wick to remove that much solder.
    DuckDodgers likes this.
  9. jondanger
    jondanger Poster Extraordinaire
    Charm City, MD
    Yuuuupppp.
    I like the solder sucker way better than a wick, but when I have to use one, I do it the way Charlie says.
    Edit to add: Aren’t you going to have to pull that board out anyway to get the jack out? Looks like it’s one of those boards that is attached to the chassis via the pot and jack nuts. If so, you’re going to have to take the board out to back the throat of the jack out the chassis hole.
  10. Monkey_Relish
    Monkey_Relish TDPRI Member
    South East Corner of Oz
    What I would do is to cut away at the input jack with a set of small side cutters. Hack it away until there are only individual legs. Then re-solder each leg, and use a set of pointy nose pliers to pull out a leg at a time when heating it with an iron.
    Mr Relish
  11. Wally
    You can use a Switchcraft input jack to replace that plastic PCB-mounted jack. The Switchcraft will be hard-wired to the board and will never need replacement.
    corn husk bag, Andy B, BobbyZ and 3 others like this.
  12. Axis29
    Beaumont, CA
    I'm gonna add my opinion that it;'s time to remove that board... and use a sucker on a PCB. I learned that lesson last year for good when I screwed up my '59 Bassman RI and ended up having to just replace the innards with new hand-wired guts.
    Don't get me wring, I enjoyed the replacement. But, if I'd had a touch more patience and pulled the PCB, I wouldn't have HAD to do it.
    Wally likes this.
  13. Ed Storer
    Seattle WA
    Thanks to all for the advice. I do have a solder sucker and greatly prefer it.
  14. schmee
    remove the board. But if you wick it, use flux on the wicking weave. But you really need to get at those and heat it quick before you harm it. Those are a piece of cake if you can get at it.
  15. rolloman
    rolloman Tele-Holic
    SC
    Solder wick works 100% better if it has some solder wicked into it before trying to use it to remove solder. Old trick I learned years ago. Wont hold as much solder but keep cutting off the wick rewicking with solder before trying to wick up solder from the board.
  16. Alamo
    Alamo Doctor of Teleocity
    Berlin
    It's usually good to look someone over the shoulder. try this:
    bender66 likes this.
  17. Andy B
    Andy B Friend of Leo's Silver Supporter
    Colorado
    I use wick most of the time. #4 wick, not the skinny wick that is usually available. If the wick doesn’t seem to work, cut off the end so you have a fresh piece. I use a flux pen to apply flux to the contact I’m desoldering.
    Through hole pcb’s often require the use of ChipQuik especially if the original solder was lead free.
  18. CV Jee Beez
    CV Jee Beez Tele-Holic
    Duarte, CA
    I've had success with solder wick on stuff like this. I put flux on the copper before I lay it down on the solder and use just a dab of solder on my tip. Looking at your pic, i would put flux on the legs as well.
  19. CV Jee Beez
    Duarte, CA
    A 2nd glance at your pic and I realize that even if you get the solder off, you'd have to pull at an angle to free the jack. You may have to take the board out to ensure the best result. They didn't design it with ease of repair in mind. Best of luck!
    jondanger likes this.
  20. jondanger
    Charm City, MD
    Agreed.
