Solder Suckers, what's everyone using?
Discussion in 'Burnt Fingers DIY Effects' started by gimmefuel, Aug 5, 2020.
  1. gimmefuel
    gimmefuel TDPRI Member
    Duluth, MN
    Can't stand the braid, tried the bulb (meh), the spring loaded pen ones work and are affordable, trying to justify the Hako.
    what you using?
  2. Paul G.
    Paul G. Friend of Leo's
    Rhode Island
    I've got a no-name with a metal body and nylon tip. It works fine, I just keep a straightened paper clip nearby to clear the tip when it clogs.
    Treehouse and schmee like this.
  3. schmee
    Yeah, me too. The bulbs are terrible.
  4. gregulator450
    gregulator450 Tele-Afflicted
    The Dry Side
    I use a Radio Shack sucker, metal body w/ nylon tip. works quite well, but I fear I will have a hard time finding a replacement now that Radio Shack is out of business.
  5. willie
    willie TDPRI Member
    Dixie
    Using good, quality braid is an acquired skill...I wouldn't use anything else. Different sizes for different jobs using different soldering tips...
    w
    Andy B likes this.
  6. WalthamMoosical
    WalthamMoosical Tele-Meister Ad Free Member
    Vermont
    I use the generic metal tubes with the nylon tips. I made the mistake of leaving one "plunged" for many years and the spring isn't as springy now, but it still works. I also have the bigger, blue plastic Sodapult for when I really get angry. The bulb has its uses, but they are fewer. The braid seems best for taking solder off of a circuit board, where you can press down on the braid with the iron tip and push it around. Not something I do very often.
    If I did a LOT of desoldering I might be interested in the fancier thing.
    So, yeah, mostly it's the metal tube, even with the weakened spring.
  7. Churchjack
    Churchjack Tele-Meister
    Plain ol’ springloaded thingy. Works.
  8. JuneauMike
    Alaska
    Cheap radio shack spring loaded sucker for big blobs of solder. Braided wick material is ideal for cleaning up solder otherwise.
    aging_rocker likes this.
  9. basher
    basher Tele-Afflicted Silver Supporter
    Washington, DC
    I've always used braid, myself.
  10. corliss1
    Lansing, MI
  11. jhundt
    jhundt Doctor of Teleocity
    Netherlands
    I prefer to heat the joint with my 60W Weller soldering gun (with lights!) and blow all the solder away with the air gun on my compressor.
    This is, without any doubt, the most personally dangerous way of removing solder. If you are worried about personal safety, and eyesight and things like that - DO NOT DO THIS. Or at the very least, you might want to wear gloves and a long-sleeve shirt and goggles and a hat, etc etc. I myself never bothered with all that.
    Desoldering a joint takes one second. All the blown-off solder blasts all over the room, but it has all cooled to tiny beads by the time it sets anywhere. Residue inside the amp or on the board is easily removed with a stiiff-bristle brush.
    All that braid stuff is just to slow and finicky. And apparently, from a post above - I need to use good, quality braid in different sizes, and with different soldering tips.
    I don't know about you guys, but who has time for all that? It's an amp. It ain't the Taj Mahal!
    Heat the joint, blow the solder away. One second. On to the next task.
    DISCLAIMER: don't try this at home, and blame ME if something goes wrong. I do it all the time, but maybe you don't work the same way I do.
    Treehouse and jsnwhite619 like this.
  12. Switchy
    Switchy Tele-Afflicted
    Arizona
    I like the braid. You're going to need to use the braid anyway to clean up the pad.
    But everybody works on different things, so do what works best for you.
  13. pj1440
    pj1440 TDPRI Member
    Somerset UK
    I have been using an Engineer SS-02 for a while now, made in Japan, its smaller than the usual sucker but very nice quality, the tip has a replaceable flexible silicone tube, so it gets much better suction than the usual type. Also the red anodised button looks nice :)
    aging_rocker and Nickfl like this.
  14. zippofan
    zippofan Tele-Afflicted
    Pennsylvania
    I've been using an Edsyn Solder-pult forever, but for single pad desoldering I use Chem-wik. When I went to soldering school (mil-spec) they went over desoldering with braid as much as making a good solder joint.
    That's not to say I've ruined PCB's with too much heat with braid, but not that many in the last thirty years at least. Most recently I ruined a submini tube daughter board, but that was on the third tube (that finally biased!)
  15. tele_savales
    tele_savales Tele-Holic
    Brooklyn, Joey!
    I got one of those. i have had a really hard time with it being to small, to smooth and too fumbly to operate efficiently. Great solder sucking power tho..
    Finally I got a 3 pack of the big blue cheapies after flailing with it for months.
  16. ICTRock
    ICTRock Tele-Afflicted
    Tampa,FL
    there's a chinese knockoff of the hakko if you just have to have it automated but the spring-loaded sucker, some braid, and some flux works as well
  17. Nickfl
    Nickfl Friend of Leo's
    I got one of those for Christmas, I like it a lot. Especially for PCBs and things like that which really need to be sucked out well to be taken apart.
  18. rstaaf
    rstaaf Tele-Holic Ad Free Member
    Here
  19. Wallaby
    Wallaby Tele-Afflicted Silver Supporter
    Midwest
    I would love to find one that works well - mine is horrible no matter how clean I keep it or if I oil the gasket for a better seal.
    I have found with braid painting some flux on the braid helps quite a bit.
    Engine Swap likes this.
  20. galaxiex
    galaxiex Tele-Afflicted
    Edmonton, Alberta Canada
    Ahh yes, the Chinese S-993A....
    I have one, it works ok,
    but certainly not on par with the Pace.
    Parts are available for the S-993A thank goodness, I've needed to rebuild mine several times....
    https://www.ebay.ca/itm/S-993A-110V...294995?hash=item421e021713:g:wu8AAOSwNZFfLSas
    That is a sweet machine, wish I could afford it.
    corliss1 likes this.
