RadioFM74
I agree.
But maybe the most objectionable thing about the S-1 is the added leads, the added solder joints, and the resultant increased level of gratuitous noise. Bajas are not quiet guitars. I wouldn't mind if they were quieter and removing the S-1 will do that. But the Baja stock pickups are not RWRP. I wish FMIC would revise the model, make the stock pickups RWRP and delete the S-1 (leave the 4 way) and put some vintage knobs on it.
Oh, just to clarify, I hear what you're saying but I do in fact use the 4 way switches a whole lot. I spend more and more time either on the Bridge alone or B + N in series.
Like the OP I never used S1 and 4-way and found it inconvenient, both because of the added wiring and because I like to flip without problems between neck and bridge pup. But as I like my Tele, I pulled (and kept) the original harness and installed a new one. Easy-peasy. That said, I can totally see the other reasons that could justify the OP swap (7.25 and if you don't like the Baja neck). (I said: if!)
