So, I bought this cheap Chinese neck for $47
Discussion in 'Tele Home Depot' started by Norrin Radd, Feb 22, 2020.
  1. Norrin Radd
    Norrin Radd Tele-Holic
    Saint Paul
    It arrived today after 8 weeks from ordering on eBay (and spending an extended stay in US Customs in Chicago). As you might expect, it wasn’t exactly ready to drop in and go!
    Besides having a lot of finishing issues on the back of the neck and on the binding, the frets are very rough (but surprisingly level!), the tuning holes were almost too close together and the neck appeared too wide and deep to fit the MJT body I have for it! :mad:
    My first instinct was to post here several hours ago and ask for advice. I did not do that. I’ve put together many partscasters and worked on tons of guitars. I decided to pull up my big boy pants and fix this myself. After all, I knew the right thing to do (sand the neck to fit) and the wrong thing to do (sand the neck pocket on the guitar).
    Well, I don’t have much in the way of sanding tools other than paper and blocks, so I went to work with my hands. It took a bit of time (and of course the finish is bare on the end now), some improvised tools (it’s amazing what you can make with just a work bench, 2x4 scraps, sand paper and clamps!) and some sore fingers but I got it to fit properly (victory!) :cool:
    I attached it and drilled the neck holes (another 1st for me) and strung it up after tuner install (no room for even a hair between the backs of these 70’s style F tuners!). I’m happy how it’s going and pleased I took it on without using you guys as a crutch!
    Tomorrow morning’s list looks like this:
    • Adjust the nut slots to proper height
    • Adjust string height
    • Install string trees where necessary
    • Intonate
    • Steel wool polish the frets
    • Adjust clamp on input jack
  2. bender66
    on my bike
    That finish on the body is crazy.
    Cant wait to see the neck on it.
    Arch Stanton and Norrin Radd like this.
  3. Chunkocaster
    In space with Ziggy
    I like the look of that body too. Good luck with the neck, lucky you got the tuners on there without a problem. The last cheap china neck I bought had the tuner hole spacing all over the place. I got it to work but not with the vintage tuners I wanted to use.
    24 track and Norrin Radd like this.
  4. bgmacaw
    bgmacaw Friend of Leo's
    Near Athens GA USA
    Nice build.
    I've got a KMise neck on the way, a Dano style headstock one, to pair with a GFS closeout Strat body. I saw the one you bought but decided against it based on the orange-ish color probably not working with surf green. I just hope it gets here sometime.
    Norrin Radd likes this.
  5. Norrin Radd
    Saint Paul
    So I got it assembled and did a little work this morning. Looks like it's time to invest in some fret files. I polished them with steel wool but the frets are still gritty/scratchy feeling when bending across. And my saddles are pretty high up - might take another couple mm of height off the heel of the neck. The electronics all work perfectly! :D The neck is surprisingly chunky and feels pretty big in my hand (it's close to my U shaped .90-.97).
  6. rangercaster
    portland, or
    Play that thang !!! That'll polish those frets in no time...
    Norrin Radd and whoanelly15 like this.
  7. PlainAllman
    PlainAllman Tele-Afflicted
    Van Zandt Co, Texas
    Very nice! Love that chameleon paint. I see purple and blue. Does it have any other tints to it?
    crazydave911 and Norrin Radd like this.
  8. mkdaws32
    mkdaws32 Tele-Afflicted Silver Supporter
    Moncton, NB Canada
    That looks fantastic. I have a cheap neck on the way as well - should be here any day. I cant wait to see how good (or bad) it is ;) $39 CDN, so REALLY cheap! I have some woodworking experience and am reasonably mechanically inclined, but not much experience on guitars other than electronics and setups. But I am never afraid to jump in and take on any project ;)
  9. Norrin Radd
    Saint Paul
    A
    Actually, that’s just the lighting playing tricks with the colors! It’s just a straight up Crown Royal metallic purple
  10. Norrin Radd
    Saint Paul
    Absolutely jump in! How bad can it be for $39, right? I figured with the way almost everything is CNC cut anyway, how bad could it possibly be? I mean, even when I buy a brand new neck from Musikraft or all parts, it still requires all the finishing touches to get it precisely the way I like it, so why not see what I can do with one for less than 50 bucks?
    The big difference of course, is the fret work and the finishing work. But that is stuff with the right tools and effort, you could probably make work on one of these things anyway. That’s why I decided to give it a go. Good luck!
  11. TheDams
    TheDams Tele-Meister
    Minneapolis
    I've had frets that were also pretty rough and needed a good polishing on a couple of Squier.
    These took care of it surprisingly well ;)
  12. 24 track
    kamloops bc
    my chibson had epiphone tuners, and when I replaced them , they had sleaves inside the holes , I removed those and it was reamed for gibson tuners ,that was lucky.
    Norrin Radd and Chunkocaster like this.
  13. 24 track
    kamloops bc
    I guess the most important part is, how does it play?,that fret board matches the guitar very well, and if its a player ......bonus1
  14. Chunkocaster
    In space with Ziggy
    I wish I was so lucky, the tele neck I bought had 10mm holes which I wasn't expecting but they were unevenly spaced for vintage tuners and had uneven gaps between them on the rear.
    I ordered some Wilkinson mini gotoh style tuners for it on ebay for another $20 bucks. They look like the ones on my d35 copy and some Gibson les pauls only they have smaller buttons and are 6 in line. Still kind of classic looking but heavy. Its for a telebird so kind of fitting with the Gibson hybrid look. You cant really tell they are unevenly spaced on the back because the backs are not hard up against each other like on vintage kluson style.
    24 track likes this.
  15. Norrin Radd
    Saint Paul
    Got a link for those?
    It's close right now. I'll update after I shave that heel just a tad more!
  16. 24 track
    kamloops bc
    if you think about it. It was lucky they added too much matterial to the neck that allowed you to work it , if it was the other way around with too little it would have been useless, but that looks hot ,man , I like it
  17. Allan Allan
    Allan Allan Tele-Holic
    Illinois
    If you shim the neck pocket that'll get the saddles down.
  18. TheDams
    Minneapolis
    Here ya go !
  19. Norrin Radd
    Saint Paul
    Thank you - purchased!
    Well, as I was going through the setup I made a booboo. As I was filing the g string nut slot I apparently put a bit too much effort into a single stroke and gouged the cheap plastic nut like the glaciers did to the Grand Canyon. Honestly I think if I had exhaled hard enough I would have cracked that nut. o_O
    So, overreacting the way I do I immediately ordered an LSR nut and some tools to install it. Got to build up that tool supply somehow! :D
  20. Norrin Radd
    Saint Paul
    I said up above I ordered an LSR nut - while that is true, I decided to pull up the big boy pants again. A while ago, I bought these:
    Blank bone nuts - with the idea of crafting my own. I was short some tools (still am) but went and bought this this morning:
    A little 5 inch clamp to my work desk disc sander - with the idea that I could use it to make nuts out of one of those blanks. To my surprise - I was right!:eek: The only part I'm missing is some way to polish the nut as the top of it still looks freshly sanded.
    Good news is I can now craft a perfectly functioning bone nut myself! That will save me tons of $$ in the future. :)
    TheDams likes this.
