So I’ve had this neck laying around...
Discussion in 'Stratocaster Discussion Forum' started by Jakedog, Jun 2, 2020.
  1. Jakedog
    The North Coast
    Beautiful flamed maple neck. Gorgeous rosewood board. Abalone dots. Flat radius. Big frets. Two way truss rod. Really nice neck.
    I bought it off a guitar repair buddy of mine maybe 7-8 years ago. He was cleaning out his junk boxes and just wanted stuff gone. IIRC, I gave him $30 for it.
    Ya see, the heel was Swiss cheese. The rounded butt has been cut off to make it fit on a T-style body, and it had been drilled (poorly) nine ways from Sunday. Whoever he got it from had to have had it on at least three different guitars.
    When I got it, it was drilled for a standard fender bolt pattern. But the holes weren’t square so the neck wouldn’t align right, and two of the holes were stripped.
    I decided this evening that I’d like to try it on my new (to me) player series Strat. So I dug it out, and I’m going to work on it.
    So far I’ve drilled out the fender pattern bolt holes cleanly, and doweled them wicked tightly. The holes near them have also been filled, though not nearly as cleanly, and not by me, but I’m hoping for the best. It’s a gorgeous neck. Cross your fingers...
    So much flame it’s hot to the touch. The photo does not even close to do it justice.
    All drilled out and doweled up.
    Cut off clean and sanded flush.
    Rufus, Blue Bill, thechad and 7 others like this.
  2. Toadtele
    Toadtele Tele-Afflicted
    Idaho just the tip
    That is perty. Good luck with it!
    Jakedog likes this.
  3. Dana Rudd
    Dana Rudd Tele-Meister
    Greybull, WY
    Should look good when properly mounted.
    Jakedog likes this.
  4. Collin D Plonker
    Collin D Plonker TDPRI Member
    Delaware
    I think you should do something about the heel. It has to be tight, and you have to make sure it sits in the right place on the scale.
    Gardo and Jakedog like this.
  5. Jakedog
    The North Coast
    The issue I’m having now is that the end had been cut off to fit a T style. I don’t think there’s any way to keep it aligned properly in this strat pocket without that Rounded heel bit on there. So right I’m painstakingly reconstructing it by shaping a little chunk or hardwood by hand. I roughed it in with a dremel, now I’m fine shaping it. With sandpaper.
    Collin D Plonker and Chip like this.
  6. Jakedog
    The North Coast
    We were posting at the same time!
  7. Chip
    Chip Tele-Afflicted
    Macedonia, Ohio
    Are you doing this work on your new workbench?
    Jakedog likes this.
  8. Obsessed
    Montana
    Ahh, gotta find a cool project for your new workbench. Gorgeous flamed maple. Definitely worth the effort. Patience and stick with it. Good luck.
    Jakedog likes this.
  9. Ricky D.
    Ricky D. Doctor of Teleocity
    Raleigh, North Carolina
    Is that a U-Haul pad on your bench top?
    Jakedog likes this.
  10. Jakedog
    The North Coast
    Yep. Works great!
  11. Collin D Plonker
    Delaware
    If that doesn't work you could shim the neck pocket with maple veneer.
    Jakedog likes this.
  12. trev333
    Coolum Beach,Australia
    Same here Jake, I've got a gorgeous flame/birdseye Maple neck laying around here.... it came with a one piece Alder body from a workshop clearance 10 yrs ago...
    it's a lefty neck though....and I don't do reverse headstocks.. shame that...:D
    once I started playing/building teles they both got shelved....:rolleyes:
    Jakedog likes this.
  13. Fretting out
    Fretting out Friend of Leo's
    Land of Mary
    “Wicked tightly”
    Does “the north coast” happen to be in Boston?
    Jakedog likes this.
  14. Jakedog
    The North Coast
    No way could I leave that stuff laying around!! I love reverse headstocks.
    trev333 likes this.
  15. Mad Kiwi
    Mad Kiwi Friend of Leo's
    Land of the Long White Cloud
    Courier to NZ :)
    Jakedog likes this.
  16. trev333
    It had been used as a righty when I got it... as the orig logo shows...
    I did set it up that body with a sss PG and it was so lively it would vibrate when you played it...
    someone had painted the one piece alder body, Red....:eek:.... but the guy had sanded it off and put a clear coat on it .... thankfully....:oops::cool:
    Jakedog likes this.
  17. Blue Bill
    Blue Bill Poster Extraordinaire
    Nice sneakers. Fingers crossed, good luck!
    Jakedog likes this.
  18. ElJay370
    ElJay370 Tele-Afflicted
    Los Angeles, CA
    Nice flame on that one.
    I’ve plugged and redrilled my share of chewed up necks. As long as you use good hardwood dowels, let the glue cure completely, and trim everything off clean you shouldn’t have any problems.
    Jakedog likes this.
  19. Rufus
    Rufus Tele-Afflicted
    NW Atlanta
    Reverse headstocks are the way to go...
