"Snap..Crackle..Pop"
Discussion in 'Amp Tech Center' started by Televised, May 8, 2017.
  1. Televised
    Televised Friend of Leo's
    Portland, OR
    Picked up a used Jet City 20 watt amp head a few months ago. When I started using the effects loop I began to experience some significant popping noise....with the amp I mean.
    After nosing around Google, the symptoms seem to add up to "DC leakage".
    What's weird is that I'm only using one pedal in the effects loop and I only experience the problem when I'm using this pedal with the effects loop.
    Pretty simple solution was to quit using the effects loop and run all pedals in front of the amp. This is what I'm currently doing and it works fine but was just curious if anyone has come across effects loop popping before.
    Thanks
  2. Platefire
    Platefire Friend of Leo's
    North Louisiana around Many
    Thinking??? I have worked on amps where there were jack switches not working properly on the effects loop and corrected it with some good contact cleaner. Spray contact cleaner in one jack at a time then work a 1/4 patch cord back and forth in the jack several times before the cleaner dries. Do it to both jacks. Then try it. Platefire
  3. robrob
    United States
    Are the effects jacks mounted to a PCB? If yes the contacts might be breaking on the board.
