Cosmic Cowboy
I really enjoy building them. If you have some tools, its a blast. Not rocket science either.
I have the Vox and really like it. It's deep and ported and has relatively good bass. I wouldn't say it sounds like a 12" or 10", but it sounds good in its own way.My adventures in small speaker experimenting has been driven by other interests, namely what is the smallest cab I can travel with and get a useable sound. I have the Hotone cabinet, many variations of things like the Blackstar mini amps. 3 different shades of Ear Candy 2x6 cabs, The 8" Randall (sealed), the 8" Vox (open), a "custom" weber 8" (open), several 1x6 and 1x4 cabs (home hifi cabinets) with Eminence Alphas and other Pro PA drivers and a few 2x8 cabinets.
If you are not wanting to drag your big amp around... the Vox 1x8 is small and can get loud, putting a Weber in it would make a big difference, no matter what style you play. At that point though you are way ahead $$ to get the smallest 1x12 you can find, then call it a day. If cost is not a problem, the DV Mark Little Jazz is unbelievably good and would take the pre out of your heads easily.
Nice work!I see you are in an apartment and may not have access to a workshop. Even if you just used a patio, with pretty simple tools you could probably do something like I did if you want to stick with an 8" speaker. This is a converted wine crate that you can buy from Total Wine or a similar large distributor for about $10. They often have box joint corners. Because one panel was thin, I lined it with lauan plywood using brads. Drilled and added dark wood dowels and glued all the corners. Made the baffle from Baltic plywood. Then installed a Celestion TF0818 that I found used for $30 shipped. This speaker is used in some Quilter combos and packs a wallop. I put a solid back on the box, but made it so I could remove half.
View attachment 1074530 View attachment 1074531 View attachment 1074533 View attachment 1074534 View attachment 1074535
A Monoprice 1 x 10 or 1x12 perhaps. What qualities of a cab would impress you ?Simple as that. I have two small amps (Orange Micro Terror and Hotone Diamond Mojo) but I need a cab to play them through so that I don’t necessarily have to tote my good amp. I tried the Orange 8” back when I bought my Micro, but recall being unimpressed.
What you folks suggest?
Nice. That would even match my bare pine PRII!I see you are in an apartment and may not have access to a workshop. Even if you just used a patio, with pretty simple tools you could probably do something like I did if you want to stick with an 8" speaker. This is a converted wine crate that you can buy from Total Wine or a similar large distributor for about $10. They often have box joint corners. Because one panel was thin, I lined it with lauan plywood using brads. Drilled and added dark wood dowels and glued all the corners. Made the baffle from Baltic plywood. Then installed a Celestion TF0818 that I found used for $30 shipped. This speaker is used in some Quilter combos and packs a wallop. I put a solid back on the box, but made it so I could remove half.
Yeah, I’m toying with the idea of DIY. I have a (crowded) garage, but it’s full of other projects I need to get to.My solution: Pine DIY
(now the cab is all white!)
Portable and not crappy-sounding.A Monoprice 1 x 10 or 1x12 perhaps. What qualities of a cab would impress you ?
It has a door, so I would set it up so that it can be used open OR closed.Well, I guess this is going to be replaced with a DIY cab thread—I stumbled onto a $5 microscope case on eff book marketplace, and the seller said “I just want it out of here, I’ll leave it on the doorstep, don’t worry about the $5.” It was even right on my way home from work. Now the questions are, what speaker, closed or open back? It’s 8 1/2 x 10 x 15.
View attachment 1076974 View attachment 1076975
That’s the way I’m leaning (I started a diy thread).It has a door, so I would set it up so that it can be used open OR closed.
FWIW, here are their 1x10 cabs (I have both)This cab was mentioned favorably in a previous post:
SubZero GC112 1x12" Guitar Cabinet
Under a hundred bucks...
I can recommend a Carvin V112E 1×12" closed back guitar extension cabinet. I get a good sound with a coupla different amps. It's got a Eminence GT12-8 speaker, weighs just 25 lbs. and costed me $180 bucks new.Simple as that. I have two small amps (Orange Micro Terror and Hotone Diamond Mojo) but I need a cab to play them through so that I don’t necessarily have to tote my good amp. I tried the Orange 8” back when I bought my Micro, but recall being unimpressed.
