Small Fender Solid State Amps
Discussion in 'Amp Central Station' started by Velorex, Nov 19, 2020.
  1. Velorex
    Velorex Tele-Meister
    Berlin,Germany
    Hello Everybody!
    Normally i use my SF Princeton.
    I also have an old sidekick 5o Bass amplifier which sounds quiet OK
    and a Squier SP 10 with crappy built in Speaker.
    Are there any small (under 50 watt) Fender solid state amps useful?
    Especially the older ones, Frontman etc., cheap for home use?
    Do they all have crappy built in speakers lacking brilliance?
    What are your expieriences?
    velorex
    PhredE likes this.
  2. Marc Morfei
    Marc Morfei Friend of Leo's Silver Supporter
    Wilmington, DE
    I have a Mustang that I use for a headphone amp and home practice. It's fine. People rave about the Super Champ which is a SS/tube hybrid. If you are looking for something small for home use, the Roland Blues Cube and Yamaha THR get a lot of love around here.
  3. unixfish
    unixfish Doctor of Teleocity Silver Supporter
    Northeast Ohio, USA
    A used Mustang III V2 will run $150 or so (US dollars). A Mustang II V2, which is smaller and lower powered will be about $100. Both of these do a good job of decent sound without needing big volume.
    The Champion 50 and Champion 20 are inexpensive, and do a good clean sound to put a pedal in front of.
    The Angle likes this.
  4. INFANT
    INFANT Tele-Holic
    Stoney Creek, Ontario, Canada
    any Roland Cube series amp gets a lot of love too! Boss Katana 50 watt is also a nice SS amp for home use with its selectable power switch.
    Unfortunately the OP is asking about small “Fender” amps and we are giving him non Fender options.
  5. glenlivet
    glenlivet Tele-Afflicted
    Marco.......Polo......
    Cheap fender SS amps are often much improved by a simple speaker upgrade....you don't even have to go with a super expensive high end speaker...just a step up from what they come from the factory with is often a pretty good upgrade.
    The Frontman 25r's are often paired with a Ragin Cajun for pretty decent results.
    Of course...a lot depends on the sound you are looking for.
    The bonus is...the Frontman 25r's are dirt cheap....so it's a pretty low risk venture to just try a different speaker or two, or heck...get two...set them up in stereo with a wet / dry / different speaker combo..... Don't underestimate the sound of 2 small amps, they can sound really good with some tweaking.
    If you can find them, I kind of like the old Harvard / Yale / London SS amps from the 80's. Decent clean sound, good reverb, cheap. Stick a $35 Joyo American sound in the FX loop...and you are all set.
    PhredE likes this.
  6. Wulf
    Wulf Tele-Afflicted
    Saltburn England
    i had one in the 80s...lil 10 watt thing...sounded like a wasp in jam jar
    cant remember which model it was...i had it given...
  7. harpdog
    harpdog Tele-Holic Silver Supporter
    near Chicago
    Champion 20 sounds pretty good but a little hissy
  8. Willie Johnson
    Willie Johnson Tele-Meister
    Chicagoland
    I'm kind of jonesing for an old Princeton Chorus that I can use as a 2x10" extension cab, with the benefit of a backup clean ss amp.
  9. Chiogtr4x
    Manassas Park, VA
    I'm VERY happy with my pretty new/used Fender Frontman 25R ( bought used for $50 on Cl in March)
    I LOVE its clean tone ( in the BF/SF clean ballpark) and real Spring Reverb, I have used it every weekend for low volume R&R/blues gigs since June- with an SG, Strat, Dano
    My particular Frontman came with an aftermarket Celestion 10"'-Thirty which I found good-sounding, but maybe a little too thin in the midrange, believe it or not.
    So I replaced it with an Eminence Legend 1058 and this amp sound just great clean or overdriven ( I use a few OD's at low Drive). The $$ for the speaker is worth it! ($65)
    Very happy- cheap, light, LOUD ( when needed), sounds like a Fender!
  10. mexicanyella
    mexicanyella Friend of Leo's
    Troy, MO
    A kid who lived down the hall in college had a Sidekick Reverb 35, a 1 x 12 combo, that sounded surprisingly good for medium-gain crunch-type tones. It didn’t get anywhere near metal-levels of saturation but it was a nice sounding, light, portable amp.
    PhredE likes this.
  11. CarsAndGuitarsYT
    CarsAndGuitarsYT TDPRI Member
    Louisiana
    I don't have a picture of MINE, but here's what I used to use:
    It's a good practice amp, and it's actually pretty loud. It came with my first electric guitar (Mini Squier Strat) and still being used today. It's cool. The only add-on I use is a reverb pedal because the amp doesn't come with reverb.
    Tyuk and Crobbins like this.
  12. PCollen
    PCollen Friend of Leo's
    Man of the World
    Look at the LT25 small modeling amp...$149
    Billy3 and DougM like this.
  13. guitarmikey
    guitarmikey Tele-Afflicted
    Bucharest
    Had a Frontman 25, then the 65. Both sounded great on cleans. Especially after I went with Ragin’ Cajun in 25. Soon had to let them go... absolutely great amp for clean, with... very afordable price!
    PhredE likes this.
  14. J-bass&Tele
    J-bass&Tele Tele-Meister
    After using my Vox Cambridge 15 (similar to a Pathfinder but with a 12ax7 preamp tube) for a couple of years for tiny gigs I started looking for a small, solid state Fender to pair it with. A couple of them was actually given to me, both having some issues though. A Champion 110 and a Frontman 15r.
    Until I get them fixed, I use a Fender Rumble 15 as the wet (+dry) amp with the Vox as the dry. Bought the Rumble as a livingroom bass amp but together with the Vox it sounds really nice for guitar. The Rumble is very clean and delay/reverb pedals sounds great through it.
  15. DADGAD
    DADGAD Friend of Leo's
    Earth
    My go to small SS Fender is the Bronco. You can see most of it on the rights side in the picture below, sitting on top of a Peavey amp.
    The amp has a 8” speaker and a switch to select between clean and dirty. The trick for sweet toanz is to select the dirty side and dial back the gain. It gives a nice fat clean sound.
    I originally bought it for the cab to build a tweed Champ. But the Bronco turned out to be a good amp.
    Alamo and Crobbins like this.
  16. schmee
    schmee Doctor of Teleocity
    I think the Champ 20 and 40 are pretty popular.
    I like my little Crate Powerblock as well as any I've had. KISS
  17. Mike M
    Mike M Tele-Meister
    The Tone Master Deluxe is amazing, and if you want a "small amp" set the attenuator to .5 or .2 watts
  18. INFANT
    INFANT Tele-Holic
    My sons Bronco is still at my house and in the past I would use it when we would play at Nursing Homes. I’d stick a chorus and delay or reverb pedal in front of it and it sounded great! I have taken the back panel off of it to make it an open back...it just seems to make it sound fuller.
    DADGAD likes this.
  19. Edgar Allan Presley
    Edgar Allan Presley Friend of Leo's
    Colorado
    In a basement closet I have a cheapo Champion 30 amp I bought in 2000 or 2001 and actually gigged with a lot back then in a strange little cabaret band with a fantastic Czech accordion player. I didn't have a car, so I wheeled the amp, my guitar, and a bowling bag for a couple pedals and cables in a shopping cart on cobblestone streets. Hence, the reverb springs are a little loose and clangy.
    I remember the amp having a pretty good clean sound if I maxed bass and mid knobs and kept treble at half to three-fourths. I should dig that amp back out.
  20. bsman
    bsman Friend of Leo's
    Santa Clara
    At the price they charge for them, they damn well better be amazing!
    PhredE and Mike M like this.
