I’m setting up my elderly MIM tele for slide. Raised the action and set the strings so that the slide rests with even pressure in each as I rest it in them in my normal playing position.
Now, intonation. It sounds out of tune on the higher frets but it’s occurred to me that, as with slide playing you bend the strings very little towards the frets, I should not be fretting at the twelfth, more just resting the slide above the fret. The note should then be in tone with the open string. Is that correct? I’ve set it up as per usual and still have a noticeable problem when I use a slide .
