Sizing wire for heater circuit... (5E3)
Discussion in 'Shock Brother's DIY Amps' started by DrPepper, Apr 5, 2021.
  1. DrPepper
    DrPepper Friend of Leo's
    Frying Pan
    I'm building a 5E3 clone'ish amp. Getting ready to wire the heater circuit. I have 18 & 21 ga solid core copper on the way but, the way I am routing I might come up short with the 18 ga. but, I ordered plenty of 21 ga. By the numbers, the 21 ga. should be rated at over 3.5 Amps from what I can find ... So, 21 ga. should be sufficient, right?(2 12**7's and 2 6v6's)
  2. corliss1
    Lansing, MI
    You'll be fine.
  3. Muzzy
    Muzzy TDPRI Member
    Use the 18 to wire the power tubes and convert to 21 for the preamp tubes. That's usually what I do anyway.
    Nickfl likes this.
  4. DrPepper
    Frying Pan
    Thanks
  5. SerpentRuss
    SerpentRuss TDPRI Member Ad Free Member
    North Carolina
    On my last build, a hybrid, I only had one tube. At first, it was very noisy. Then I re-wired the heater circuit using a shielded two-conductor instrumentation cable for the heaters. This wire consists of 2 insulated 18 gauge wires (twisted) and a tinned, 18 gauge drain wire. The wires are jacketed together with foil shielding. I attached one end of the drain wire to my ground bus and it significantly reduced the hum. I think the only way to use this wire effectively with multiple tubes would be with dedicated runs, no daisy-chaining, so it might clutter up your build if the design has a lot of tubes. I'd guess it's about 1/4 inch in diameter.
  6. Tom Kamphuys
    Tom Kamphuys Tele-Holic
    The Netherlands
    Heater voltage is only 6V. Electric fields will be small. The current is high and thus the magnetic field also. Shielded wire does not protect against 50/60Hz magnetic fields.
    Keeping the two conductors close does help, twisting them even more. That might have caused the improvement you mention.
    Paul-T, Oldsmobum and SerpentRuss like this.
  7. SerpentRuss
    North Carolina
    That's good to know. I used it because I had it on hand and I thought it might help.
  8. schmee
    schmee Doctor of Teleocity
    I avoid 18 ga on them all now. Been using the standard Fender gage used on all but the heaters for a long time. No issues even in 6 pre tube amps. The stiff 18 ga puts a lot of strain on things, especially today's thin cheap tube socket tabs.
    The "aha!" moment occurred after taking apart old Hammond organ chassis that had like 16 tubes in them... all driven by tiny heater wire.
    King Fan and dan40 like this.
  9. Lowerleftcoast
    california
    5E3 only has 4 tubes on that filament string. 22AWG is fine.
    It is easier to manipulate the smaller wire.
    It also fits into the terminals easier.
    KISS... don't bother with the 18AWG... Marshall didn't. hah.
  10. dan40
    dan40 Friend of Leo's
    Richmond Va
    22awg for me also.
  11. King Fan
    Salt Lake City
    Another 22ga convert. I believe a guy named Jim Marshall was an early adopter...
  12. Urshurak776
    Urshurak776 Tele-Afflicted
    Charlotte
    A buddy of mine wired his 5E3 scratch build with 22GA radio shack hook-up wire. Everything. Works fine. That was a little over a year ago. No issues so far.
    Edit: It was a 5F1.....still okay I would think.
