Size of strat vs tele pickup?
  • Thread starter fretful
fretful
Kent, UK
Seems simple but...I've got a MIJ JD Tele with strat pickup at neck position. Is it the same width as tele neck pickup? If I changed to another colour tele pickguard - I know I'd need one with height adjusting holes to side - would the pickup hole fit!?
Anyone done the same?
KokoTele
Vendor Member
albany, ny [not chicago]
Strat neck pickups are bigger, so you'll need a pickguard cut for a tele neck pickup. The pickup cavity will be plenty big, so don't worry about that one.
Jack Wells
Albuquerque, USA
????????? ........... He has a guitar with a Strat neck pickup. I think he wants to keep that pickup and only change the pickguard. Normal Telecaster pickguards will not fit unless he changes to a Tele neck pickup.
chickenpicker
UK
I'd remove the original pickguard and use it as a template to mark the new one, then enlarge the hole in the new one and drill two holes for the pickup screws.
Or I'd just leave it as it is.
KokoTele
Vendor Member
D'oh! I don't know why I read into the post that he wanted to use a tele neck pickup instead of the strat neck pickup.
BrianF
Carlsbad, Ca
BTW...the Strat pickup in the neck position is a major improvement over a normal Tele neck pickup.. not even close...!
woodman
Grand Wazoo @ The Woodshed
Gold Supporter
Pisgah Forest, NC
... unless you remove the cover from a Tele neck pickup (see numerous other threads). ;)
fretful
Kent, UK
On the MIJ JD Tele the strat pickup loses the tone control on 5 way switch's fifth position - it's full treble and too thin, but in the other 3 positions wherer you can roll off the treble (apart from the bridge pickup only) it's genuinely interesting and warm...The pickups sound really good through my Tech 21 Trademark 60 but you can't help wondering what some Custom Shop ones would sound like.
