Six Shooter in a Champ 5F1 Chassis Build
Discussion in 'Shock Brother's DIY Amps' started by James Knox, May 29, 2020.
  1. James Knox
    James Knox Tele-Holic Silver Supporter
    Phoenix
    So I have this Swart STR Tweed which I love but the Quarantine hit and the whole family is at home All day long going stir crazy and NOT liking it when I crank up my Amp and play. Even with being a 6 watt amp, it is still really loud :)
    So, in order to keep peace in La Casa, I got the idea to build a low wattage Bedroom/Den Tube practice amp. It would give me something Fun to do for awhile.
    Researching 1 watt Tube Amps I discovered the Boot Hill Six Shooter. Being a “need for Tweed” guy for many years I contacted Dave at Boot Hill and asked if his kit could be installed in a 5F1 Champ Chassis. With a little customizing, Dave put together a Turret Board and all the parts in Kit form for me so I pulled the trigger (pun intended).
    I’ve never built an amp before, but I have always done my own guitar wiring, fixed broken pedals, etc. So as I waited for parts to arrive, I started reading through the Build Threads, studying and learning from what others have done. I’m in no hurry - it’s kind of a learning and therapy project for me.
    I’ll share as I go and welcome the input and advice of the guys who frequent this Forum...
    tubegeek likes this.
  2. James Knox
    Phoenix
    I received the Six Shooter Kit and it was all I hoped it would be. All parts labeled and accounted for. Clear Layout and Schematic information. Really nice Kit.
    I had planned on working on the Chassis hardware first, but realized that the leap/bulb/jewel assembly would not allow me to change the Color of the jewel. Not a big deal to most folks, but I have developed over the years a fondness for an Amber Jewel for all my Tweed Amps. OCD, I know... sorry, lol. So, I resourced and ordered a Fender Amp bulb assembly (I already have extra Amber Jewels). Since the twisted heater wires are attach to the lamp assembly, I went ahead and stalled the AC Cable, Transformers, and Fuse post and set the chassis aside. I also went ahead and made some heater “twisted pair” like I learned from Dave’s YouTube Tutorial.
    Paul G. likes this.
  3. mjcyates
    mjcyates Tele-Holic
    Louisville, KY
    Go slow, have fun, enjoy the ride, then prepare for amp build #2!
    James Knox likes this.
  4. James Knox
    Phoenix
    Here is the Power Transformer, AC cord and Fuse installed. On one of the builds I studied here someone had suggested insulating the exposed Fuse lug, so I heat shrunk it...
    Also read here to crimp AND solder any ground lugs. Good advise!
  5. James Knox
    Phoenix
    With the Chassis set aside waiting for parts I started on the Turret Board...
    monkeybanana and Paul-T like this.
  6. James Knox
    Phoenix
    Pre wired And attached the input jacks to the board...
  7. James Knox
    Phoenix
    Here is the back of the board...
    D'tar likes this.
  8. James Knox
    Phoenix
    Input jacks and on/off/volume pot tied in... 4F160588-BC9B-4069-958B-7B9F357367A0.jpeg
  9. James Knox
    Phoenix
    Wired heaters to new lamp assembly
  10. James Knox
    Phoenix
    Installed turret board in chassis along with the pre-wired Switch and input jacks.
    5CCD3E3D-B21C-4F98-946F-E12EBC0F91FB.jpeg 3AD800A4-562D-458D-8E7D-B69A2760128E.jpeg DA97EB45-0E38-489F-B710-4133ECA87031.jpeg BDDC1F40-F11B-46B5-A234-1D1082F943F7.jpeg 39CF7E92-D411-46FC-8405-46C430A7D53A.jpeg ECB14BAD-02F3-4FF3-B135-3B8A65C65E1C.jpeg
  11. James Knox
    Phoenix
    Everything is wired up except the Output Transformer leads. I think I read somewhere there is something you have to do first. Does anybody know?
    I’ll do some research.
  12. Lowerleftcoast
    california
    Are your heater wires correct? I am not use to seeing pin4 and pin5 taking each heater wire.
  13. James Knox
    Phoenix
    I think so but I will double check! The heaters from the lamp go to 4 and 5 on the power tube, then proceed to the preamp tube, right?
  14. Lowerleftcoast
    california
    d
  15. Lowerleftcoast
    california
    Wait. I may be wrong depending on which tubes you will be using.
    Since you have the artificial center tap (the two 100ohm resistors from the lamp), I am sure you want to change the heater supply to the typical 6.3V design.
    To do so pin4 and pin5 of each tube are connected together and receive one of the heater wires. Pin9 receives the other heater wire.
    The heaters from the lamp go to pin4/5 and pin 9 on the power tube, then proceed to pin4/5 and pin 9 on the preamp tube.
    This will be the quietest method reducing hum.
    Paul-T and James Knox like this.
  16. James Knox
    Phoenix
    Here is a pic of the layout...
  17. Lowerleftcoast
    california
  18. James Knox
    Phoenix
  19. Lowerleftcoast
    california
    My bad.
    With the 6J6 pin3 and pin4 is correct.
    With the 6cl6 pin4 and pin5 is correct.
    Never mind the previous observation.:oops:
    Carry on.
    :cool::cool::cool:
    Paul-T likes this.
  20. James Knox
    Phoenix
    Hey, no problem my friend! Thank you so much for checking in and looking it over for me. It’s my first build, and I am learning as I go.
    Lowerleftcoast likes this.
