Single P90 in the bridge - 0.015 uF or 0.022 uF tone cap?
Discussion in 'Tele-Technical' started by Verzila, Jun 4, 2020.
  1. Verzila
    Verzila Tele-Meister
    WR15 8PH, United Kingdom
    I'm thinking of swapping the 0.022uF tone cap on my single P90 guitar in favour of a 0.015 uF cap. I hear it makes for a thicker, richer tone. Anyone have any experience of this mod and can give any comments?
    Thanks
  2. Ess Eff
    Ess Eff Tele-Holic
    Haha..... One man's thicker, richer is another man's muddy n dull.
    6stringcowboy and dcos like this.
  3. guspac88
    guspac88 Tele-Meister
    Winsted, CT
    Depends if you dislike the curve of your current pot, or are having trouble rolling off enough highs. If not, it won't do you any good.
  4. wabashslim
    wabashslim Tele-Afflicted
    Sonorous Desert
    A smaller cap means less highs rolled off, but in this case too little difference to make a difference.
    bblumentritt likes this.
  5. Lucius Paisley
    Lucius Paisley Tele-Meister
    Sydney, Australia
    Lose the tone completely.
  6. tubejockey
    tubejockey Tele-Holic
    the bozone
    With a single pickup, I would probably pick my cap based on the tone I want with the pot on 0, then add a tapering resistor if needed to spread the sweet spot out. This makes for a tone control that is easy to dial in and sounds good everywhere. For a P90 I typically like somewhere in the 6.8nF to .01uF range with a 500k pot. I prefer to choose a linear taper pot and add a resistor to tailor it rather than an audio taper pot.
  7. AJBaker
    AJBaker Friend of Leo's
    Switzerland
    Give it a try!
    It won't give you a richer tone, but it will mean that highs get cut off starting at a higher frequency. This could mean that you can cut off the high ice pick, while still keeping enough mids (the 'meat' of your sound), but it could also mean that your tone control becomes too subtle and doesn't do enough anymore.
    I think you'll be ok with either. Like I said, give it a try, caps are cheap and the mod is easily reversible.
    W.L.Weller likes this.
  8. Mahogany
    Mahogany Tele-Meister
    XYZ
    This.
    And use a 1 meg pot for volume.
  9. AJBaker
    Switzerland
    I disagree, a tone control is very useful for getting different sounds.
    middy, wabashslim and BB like this.
  10. john_cribbin
    john_cribbin Tele-Afflicted
    London
    With the generally large tolerances in capacitors, there's a good chance the measured values coud be close enough to make little difference.
  11. ctmullins
    ctmullins Tele-Meister Ad Free Member
    MS Gulf Coast
  12. jimbo735
    jimbo735 Tele-Afflicted
    Michigan
    I like having the Tone control I use a 0.022 without the 50,s wiring,I like to dial in were that Mid range string thunk is happening.I tried 50,s and had to go back,Your going to have to experiment some to find your Happy place.
    It works for me with the rest of the gear Im using.
  13. Lucius Paisley
    Sydney, Australia
    Then how are guitar stores going to make any money if you only buy one guitar that can do everything?
    So selfish, AJ.
  14. AJBaker
    Switzerland
    I don't believe that I said that a tone control can make "every possible sound, thereby making all other guitars superfluous". I thought I was clear: a tone control allows you to make various different sounds. Bonamassa for example has a cool video with a Les Paul where he shows what you can do with the controls.
    No one is arguing that a tone control can make every sound, I have no idea why you're suggesting I or anyone else said that.
    If you have no use for a tone control that's up to you and perfectly fine, but that isn't the OP's question.
    Please don't derail this discussion: the fact is that most guitarists (and in particular the person who started this thread) use the tone control and find it useful.
    He seems to want to adjust the tone control to suit his needs, not dump it entirely.
  15. SammyC
    SammyC TDPRI Member
    I've just installed a P90 in the bridge with a 4.7nF cap on the tone control.
    I've been really pleased with the sound, it rolls off the top edge of the sound, keeps it bright, without making it sound muddy like bigger caps can. Sounds compressed rather than muted if that makes any sense.
  16. tfarny
    tfarny Friend of Leo's
    Hudson Valley, NY
    Smaller values roll off less treble (or, really, they start rolling off at a higher frequency). .022 and .015 are not very different. It's not going to be a "thicker richer tone", but it might stay a little brighter in the upper mids when you roll back the control. I'm a fan of small tone caps.
    You might get more bang for buck by adding a switch, or push/pull to remove the tone pot from the circuit entirely.
  17. Ricky D.
    Ricky D. Doctor of Teleocity
    Raleigh, North Carolina
    Run test leads out of your control cavity, alligator clips. Get an assortment of caps, cheap ceramics work just fine. Now you can try out the various values you are curious about, then just install the one you select.
  18. radiocaster
    europe
    .015 and .022 are extremely different. I've been trying different caps in one guitar, but could never get rid of the cap sound altogether with 500k ohm pots even all the way upHaven't tried 1M, but I found no pots (edit: or caps in the circuit) too bright in another guitar where I just used tone caps. Much smaller values seem to work better there.
  19. AJBaker
    Switzerland
    Have you considered a no load tone pot? When turned all the way up, the tone circuit is completely out of the circuit.
    Not a huge difference, but slightly brighter at 10.
    You can make one yourself by scraping away some of the carbon trace inside a pot.
  20. radiocaster
    europe
    No, have not considered because I'm not interested in the sounds it can offer. I actually like the way the caps color the sound.
