I'm getting around to starting my next build - a single channel deluxe of some type. Each time the design and build process seems to get a bit smoother and more intentional, partly due to the community help here. I don't think I'll be breaking new ground, but it's reassuring to document a build here and perhaps have some company on the journey...
I am starting with a Hammond 14x6x3" aluminium chassis and a Classictone 40-18078 PT. I have a Triad OT S-146A 25w UL taps, 6.6k primary 4,8 and 16 secondaries (rating pic below) from my reclamation drawer as well as a pair of 'coke bottle' 6V6g tubes. All untested of course, but that's part of the fun...
I also have a huge 10h choke that came from a 30's Wards Airline amp. I am on the fence about using that or any other choke as a 5E3 didn't use one, but my 6L6 Proluxe build has one and is super quiet.
I think I will do something akin to a single channel 6G3 with a cathode bias arrangement on the 6V6s. The tried and tested Tweed Princeton preamp vol/tone for the first stage and then a LTPI. Instead of a second channel, I thought to make the first triode cathode bypass cap switched to have two flavours of gain.
From what I can glean, the 6.6k OT might be more suited to a fixed bias amp. Or it might not matter. Other considerations are filtering values and coupling cap values. I have a 32/16 cap can and a 8uF for preamp B+ on hand, as well as an assortment of vintage caps which I am testing for DC leakage. I'll draw out the schematic as it helps to understand the layout. Previously I have just built up the amp PtP as I go, making decisions based on grounding points and shortest runs. This seems to result in a quiet amp. This time I am thinking to use a tag board or even a pre-made 5E3 turret board I have, if enough of the turrets seem useful in the eventual layout.
Questions:
What is a good mac-based layout programme? DIYLC does not seem to want to work for me.
Is there already a schematic/layout for this. It's not a million miles from an 18w in the power section, I'm guessing.
Questions:
