Supertwang
On the 40-50 watt Fender amps I like to tame them down by: 1)install a 5R4 or 5V4 rectifier. These rectifiers will drop a little voltage compared to 5AR4 and 5U4 yet provide slow start-up. 2)install 10K + 10K dropping/filtering resistors in the power supply filtering section to drop a little more voltage and improve the AC/DC filtering section. Your output tubes will thank you. 3)bias it @ 30mA instead of 40mA. Your output tubes will thank you again. 4)install the most inefficient speaker(s) you can find/afford. 5)install a proper PPIMV,….Post Phase Inverter Master Volume.
Fender had their amps (especially the Silver-Faced) tuned up to max output they could afford to warranty. With these mods completed you reduce the output from 50-ish watts into efficient speaker(s)…. TO….@ 35 watts into inefficient speaker(s). Your tubes will also last about twice as long and IMHO improves the sound. Fender amps have the tendency to BLARE. These mods cut the BLARE off at the knees.
