A few thoughts on a refurb I just did...
I've got a new mid 60's Silvertone 1482 Amp, in near new condition. Original Speaker. Upon purchase I do my usual three things I do to all my amp refurbs:
1. Replace Electrolytic Can Cap, with 3 individual new caps. The orig can has 20uf/450V, 10uf/450V, and 5uf/450V. I installed a little vertical oriented Terminal Strip using a screw that holds the output trans. I use 22uf/500V for the first, then 10uf/450V for the next two. Replaced the 2.2k and 27k resistors voltage step-down 1/2 W resistors with 1W resistors. As can be seen from almost every video posted....the 2.2k 1/2 original Carbon Comp Resister that steps down voltage and goes from the first to second lug of the Capacitor can...Always is burnt up on this amp.
2. Replace power cord with 3 wire grounded cord. I always also put in a thermal inrush current limiter. In this case, I used a 120ohm, 2A inrush limiter. The black (hot) wire goes to top of fuse holder, then current limiter from ring of fuse holder to power switch. Then from power switch to Power Trans input. The white wire is directly connected to the other power Trans input wire. Green to chassis. As is listed in many diagrams, when replacing the power cord...fuse, current limiter, and switch are on the hot wire...in that order. All modern amps from Fender, including hand wired models...use current limiters, so do I. If you measure the voltage rush, these can hold down the peak, particularly on SS rectified amps....so the voltage doesn't exceed the Electrolytic capacitor limits on startup.
3. Then, after testing, I noticed the amp sounds dull, even on full treble. There is no reason for this as the circuit is quite simple. So, I replaced all the 0.01 uf "648" Dark Orange drop film coupling capacitors with new Polyester film Caps (there are 5). Original caps from the 60's were not polypropylene...so I use Polyester. While, I am not sure if these orig caps go bad, it is possible from moisture absorption that they do change for the worse. I've noticed when I rebuilt my old tube echoplex and replaced all the vintage orange drops that the echoplex sounded incredibly clearer with same value polypropylene caps.
Test #2: I have to say that the amp sounds clearer with better sparkle with the new polyester coupling caps. Would be interested to hear others opinion on this. I left the values at 0.01uf as original.
If I were to do it again, I would use recommend Polypropylene rather than polyester coupling caps. Why? because the amp is somewhat dull sounding with the original caps, and that's what I'm trying to fix here. You are running through three sequential iterations of coupling though the caps...2 in the preamp, and 2 in push/pull in the power section. Each amplifies the shortcomings of the one previous. Since, I'm trying to brighten the tone, I would go polypropylene to clear up the tone as much as possible.
Speaker: I also believe that this speaker is likely a dog as well. I would love to put in a nice alnico replacement, but fear it would not fit the cabinet. I usually use Celestion Ruby, Blue or Gold alnicos....but they're getting very expensive...so for now I'll leave the original. I'm sure the Celestions wouldn't fit anyways. Has anyone tried the Warehouse 12" Alnico British speaker....they are less expensive? It wouldn't fit here either unfortunately. So maybe a modern Jensen alnico, without any bell housing might fit.
Tremolo Circuit: I didn't change anything here. The 3 phase changing caps are ceramic and work fine...so I left them as they are. I've seen some videos where people change these...not sure why if they work stock?
Lastly: This amp truly shines when you plug into the instrument input, and then use a jumper to also plug into the 'microphone' input as well. The two inputs go into either half of the first 12AX7 and are then summed together into the first half of the second 12ax7. With the added gain, then this amp is awesome, with great overdrive breakup at not too loud volume. This is the magic of this amp, and why it's a keeper.
