Silicone to mount filter caps???
Discussion in 'Shock Brother's DIY Amps' started by King Fan, Jul 22, 2019.
  1. King Fan
    Salt Lake City
    I’ve seen experts suggest RTV silicone to secure filter caps in place. I’d like not to drill new holes in an old amp I’m restoring, and terminal strips would mean new holes. Also space is super tight.
    I know there are other ways. But would silicone hold OK? Painted chassis, shiny F&T caps, any issues? Any experience? Other problems you see?
  2. Phrygian77
    Phrygian77 Tele-Afflicted
    Crawfordville, FL
    I use Alex Plus, same thing my friend uses to glue down crossover components in his high-end hi-fi speakers. The only problem is the temperature rating, so inside the chassis near tube sockets might not work out so well. I haven't had any issues using it in the dog house.
    I think silicone is fine, but you want a type that doesn't have corrosive outgassing as it cures.
    magic smoke, sds1 and King Fan like this.
  3. Phrygian77
    Crawfordville, FL
    King Fan likes this.
  4. King Fan
    Salt Lake City
    Thanks, Phryg, that’s excellent.
    Phrygian77 likes this.
  5. corliss1
    Lansing, MI
    Yup - I do it all the time. Follow the corrosive advice and make sure it's specifically advertised as being non conductive.
  6. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
  7. dogmeat
    dogmeat Tele-Afflicted
    Alaska
    or hot glue
  8. corliss1
    Lansing, MI
    Hot glue is often not sticky enough to really grip a chassis, in my experience.
  9. charlie chitlin
    Kimberton
    Silicone, BTW, is rated to 400deg...but I'm guessing it handles more.
    I used it at the exhaust ports on Harleys for years, and it never gave in to temperature.
    I would also imaging that any corrosive outgassing would only happen during curing.
    I've never seen any sign of your basic hardware store silicone causing corrosion.
    Axis29, akuster777 and King Fan like this.
  10. King Fan
    Salt Lake City
    Thanks, very helpful.
    If I'm looking right, it helps to search for 'non-corrosive RTV silicone', since the ordinary stuff is corrosive (mild acetic acid?) at least during cure. OTOH it *seems* like most silicone is non-conductive, and the conductive stuff (copper-infused, eg) seems to be a specialized product. I see many of these products are rated to at least 204°F continuous, which I guess oughta be OK unless you're working right next to a tube or the PT.
  11. King Fan
    Salt Lake City
    Aha, Charlie, we were posting at the same time. In my research, even the most common RTV silicone seems rated to 204° continuous, but in the automotive section you can find products rated to 400°F, and others (Permatex ultra red at my store) even rated to 600°F.
    I like your reasoning about corrosion. I probably wouldn't put 'corrosive' silicone on PCB traces, copper, maybe aluminum? I bet you're right that it won't do anything to plastics, urethane, enamel, etc. Steel? Who knows, but some sources do support what you say about 'the cure being the disease' (to coin a phrase).
  12. VintageSG
    Yorkshire
    You can get stand-offs with self adhesive bases that allow you to secure wiring/caps with tie-wraps. The decent ones use adhesives from companies like 3M and Scotch. One fitted, they resist most attempts to remove them.
    Non-acid cure silicone does a good, if slightly messy job too.
    sds1, King Fan and corliss1 like this.
  13. King Fan
    Salt Lake City
    Thanks, yeah, I actually have one (though I'd need like 3 or 6 here). And those would be a most practical solution.
    It's just I figured nylon ties in a 50's amp would look a bit off, and I'm vain -- I can't bring myself to cover up any shiny black and gold on F&Ts.
  14. D'tar
    D'tar Friend of Leo's
    WNY
    separating the caps (no multi section firecracker) would allow one to place the filters wherever you like. PTP style with the 20uf right at p2 of 5y3, 10uf at OT B+supply tap and 10uf right at the plate of the pre tube. Assuming this is a GA9 :) Some spaghetti tubing, nos cloth covered wire and bobs your uncle.
  15. strat a various
    Hot glue melts when it gets hot ... is the problem.
    BobSmith, red57strat and corliss1 like this.
  16. tubedood
    tubedood Tele-Meister
    Orlando
    was wondering the same and went with the hot melt glue... I tried the white and clear and I liked the look of the white one better. I haven't had an issue with it getting that hot during use. I am all ears for a better suggestion!
  17. corliss1
    Lansing, MI
    See, I think that's the perfect purpose for hot melt. You have a nice surface to secure to with a confined area. But for straight to chassis, it's silicone all the way.
  18. Bill Moore
    Bill Moore Tele-Afflicted Silver Supporter
    Silver City, New Mexico
    Being in the automotive business, we use silicone a lot! Since the addition of electronics to vehicles, we've been cautioned to use only "sensor safe" products, so that's all I buy, (and I've used it on a few SS amps that had what appeared to be "hot glue" holding the caps down/together).
    King Fan and duzie like this.
  19. King Fan
    Salt Lake City
    Yeah, it just might be a GA9. :)
    You're right, keeping each filter cap in its own sector is super sano, and keeps leads short. And it's especially logical for classic PTP. Or for a 'logical-layout' board a la Doug Hoffman (note the three filters under the pots).
    I've been looking for some way to do this ever since I saw Doug's helpful list of filter cap solutions. Sadly the little GA9 isn't quite that roomy, and the PTP tie points are already clobbered with solder and buried under their wiring. But since the chassis is so tiny, I'm gonna use your idea a different way, retaining the existing input leads to the filters, but splitting their grounds. At least I think that's what I'm gonna do... :D
    tubedood likes this.
  20. King Fan
    Salt Lake City
    I see even the 'low-temp' variety of hot glue melts at 248°F, so probably OK from the temp angle unless you're trying to glue stuff to your tubes. :D
    But y'all got me wondering: How hot *does* it get inside a (tube amp) chassis? Obviously it's hotter right by the PT and over the hotter tube sockets, but even on average? Anybody have any data?
