Silent practice/recording solution for tube amp, suggestions?
Discussion in 'Amp Central Station' started by bluesholyman, Aug 1, 2020.
  1. bluesholyman
    bluesholyman Tele-Afflicted
    Greater Atlanta
    I am moving into a townhome with a noise ordinance - the view/location is worth it. It leaves me in a position where I need to practice/record a good bit of the time with headphones or at extremely low volume. I have the Dr Z airbrake but the wife might not like low volume if it can be heard in the rest of the townhome - pretty open floor plan.
    I looked at the Mesa Cab Clone, but the reviews are mixed - seems like its "good enough" for the price, but that is hardly typical for Mesa. Trying to keep the price down, but will consider the right solution and spend if needed.
    The other option is to buy a small practice amp that sounds good at bedroom volume and perhaps has USB out for the computer. I'm generally not impressed with the sound, so....its probably the lesser desired options.
    Would appreciate suggestions, especially those who are apartment dwellers and need to run an amp open for recording silently.
  2. Togman
    Togman Tele-Afflicted Silver Supporter
    Cambridgeshire, UK
    gimmeatele likes this.
  3. tubegeek
    tubegeek Friend of Leo's
    Brooklyn, NY
    Headphones fed by a cabinet simulator fed by <whatever pedals or preamp you like>?
    In other words no amp.
  4. gregulator450
    gregulator450 Tele-Afflicted
    The Dry Side
    It's pricey, but the Universal Audio Ox Amptop Box seems to be the gold standard for silent playing. It is a load box and a cab IR loader in one.
    bluesholyman likes this.
  5. Tim S
    Tim S Tele-Holic
    Upstate NY
    Weber makes a Headphone Tap (HA-50) for amps 50 watts or less. It gives you a headphone jack as well as a line out, each with its own volume. It’s passive, dead-simple and it works.
  6. bluesholyman
    Greater Atlanta
    I happen to love the sound of my amp - I would like to preserve that in the experience
  7. bluesholyman
    Greater Atlanta
    Yeah, if I could swing it, that would be it I think. Not sure if I can though....
  8. tubegeek
    Brooklyn, NY
    Tough to do and remain silent?
  9. Leonardocoate
    Leonardocoate TDPRI Member
    Ohio
    Maybe a "dry box" with a mic to your recorder. I'm not sure that I'm calling it by the correct name, but the idea is to make a sound proof box for your amp and a mic....They work great, however when I did it, it was to keep ambient noise out. I used egg cartons for sound proofing...as I recall we could barely hear the sound through the box...good luck......
  10. MilwMark
    near Arnold's
    Don’t overthink this one.
    Katana Headphone amp is amazing.
  11. klasaine
    klasaine Poster Extraordinaire Silver Supporter
    Los Angeles, Ca
    Ox is probably the best but it's $1299.00
    I use a Two notes 'Torpedo Captor-X' - $550.00 and a super close second best. I use it for recording ... and I f'n love it!
    https://store.two-notes.com/en/home/675-torpedo-captorx.html
    Any head up to 100 watts. Headphone out. Stereo/mono/reverb/compression/IRs.
    Here's a track using a cranked Deluxe reverb, Nobels ODR and a open back single 12" IR.
  12. trxx
    trxx Tele-Afflicted
    Between reality and imagination
    If you're trying to be silent when playing guitar, you're involved with the wrong sort of thing.
    Beside that, does anyone still play acoustic guitar these days? 99% of the important stuff can be practiced on one.
    Leonardocoate and StevesBoogie like this.
  13. Twang-ineer
    Twang-ineer Tele-Meister
    Open back headphones are key to enjoying playing guitar on the very quiet.... I also enjoy feeling the room "move" a bit, for that, a processor into a pair of cheap nearfields will do nicely. I'm one of those Helix cult folks....
    If your brain needs to know that you have an all analog signal path and nothing else will do..... A Marshall DSL-1 into an Ear Candy 2x6 cabinet can be very rewarding too. You need the smaller speakers to limit the low end and get a bit more sizzle in the room at volume. I can plug my Les Paul in, get real distortion and still listen in on a conference call coming through my laptop.
    I also have the Tubemeister, and at the1 watt settings the Tubemeister is much louder/cleaner etc.
  14. Collin D Plonker
    Collin D Plonker Tele-Meister
    Delaware
    Isolation cabinet?
    Leonardocoate likes this.
  15. gregulator450
    The Dry Side
    Yeah, it is on my wishlist of "Gear I Will Never Be Able To Justify Purchasing". :lol::lol:
  16. cyclopean
    cyclopean Friend of Leo's
    innsmouth, MA
    thinking really hard about music while sitting perfectly still.
  17. 19sixty3
    19sixty3 TDPRI Member
    Frankfurt, Germany
    That's exactly what the Laney Lionheart L5-Studio is for. I play the Lionheart L5 studio myself. I love that little thing to death. The Laney has a full output of 5 watts or attenuated down to 0.5 watts. Furthermore, the Laney can be run total silently using the internal dummy load which means it can be used with headphones. The T-USB interface supplies both a dry signal and the processed signal – split left and right to your DAW. That thing sounds great for rock, with an aggressive Laney bite that's great with humbuckers. The clean channel has a nice Vox-inspired chime to it that turns into a bluesy drive at higher levels, and the overdrive channel packs enough gain. Well, it’s a Laney.
    Digital Larry and bluesholyman like this.
  18. bluesholyman
    Greater Atlanta
    Yeah, these do seem appealing, but they don't solve the silent recording issue. At the moment, I am leaning towards something like a two notes or mesa cab clone, with IR.
    Seems like the best way to get the amp itself tracked without disturbing others - can practice well enough with the same scenario,
  19. stratoman1
    stratoman1 Friend of Leo's
    Virginia Beach, Va
    Hughes and Kettner TM36 here. Goes from 36, 18, 5 , 1 and silent
  20. Frodebro
    Seattle
    I ran the entire gamut of silent amp options when I was an apartment dweller-iso cab, load box, etc, and when all was said and done I found that the absolute best results came from a digital solution.
    Peegoo likes this.
