justusberlin
Paths are pretty straight forward in a schematic but I found hard trying to understand what is going on in a Layout in general so i tried to "visiualize" it. Simplified the Blackvibe 6V6 Layout (one Input, one output, etc.)
Wiring colours are not according to the way they might be generally used:
Yellow is AC signal into tubes
Green is AC signal out of tubes (except for the heater wiring)
red is DC
black is to ground
Guitar Signal (AC) path (starting in the top right corner - input jack)
PREAMP
from input jack into tube V1A yellow wire
out of tube V1A - green wire (through Tonestack into Pots)
from Pots into V1B - yellow wire
out of V1B - green wire (through caps and resistors) into Phase inverter
PHASE INVERTER
2 paths into V2A (Grid Leak and Cathode Resistor)
2 paths into V2B (Grid Leak and Cathode Resistor)
out into power section
POWER SECTION
from phase inverter into Power Tubes (6V6) yellow wire
our from Power Tubes into Output Transformer (converts AC into DC?)
from output Transformer into speaker
Power (DC) path (starting at the power Transformer)
(5V for Rectifier Tube Heater, 6.3V for all other tube heaters and 50V for Bias Tap have different colour wires)
AC into Rectifier Tube (120V from wall power outlet we get 2x 330V into rectifiert tube)
out of rectifier Tube (B+1 420v) into Filter A (e.g. 70uf 350V)
from Filter A into choke
out of choke into Filter B (B+2) and then into Power tubes
simultaneously through dropping resistor into Filter C (B+3) and then into Phase Inverter (V2)
simultaneously through dropping resistor into Filter D (B+4) and then into Preamp Tube (V1)
I used red for the DC signal into V1 and V2 and green for the AC signal (guitar signal) into V1 and V2 - it looks like to wires but it is only one wire containing both High Voltage DC and AC
Would you guys agree with all of the above or do have some parts seriously wrong? Feedback appreciated!
