Sigh. Tele Jack Issues.
Discussion in 'Telecaster Discussion Forum' started by unixfish, Apr 2, 2021.
  1. Maguchi
    Maguchi Tele-Holic
    Lalaland
    I've modded out about a half dozen Teles to Electrosocket cups and Switchcraft jacks. That's the ticket for Tele inputs. $10 in parts and a small amount of labor and you're done.
    unixfish likes this.
  2. El Tele Lobo
    El Tele Lobo Poster Extraordinaire
    Switchcraft. Electrosocket. Ye-essss...time for these it is...mmmrrrrgggrrrmmm. For every telecaster Jedi, essential they are.
  3. fender4life
    fender4life Friend of Leo's
    los angeles
    I think one of the issues with the stock tele is that the clip they use varies in material quality and thickness between many models. You have fender USA, MIM, MIJ, and squiers that may at times all use different clips and they may even change within the same model at times due to supply and cost. Theres just no standard and they often use total garbage pot metal thats also too thin. I think the best ones which are thicker and better quality metal when installed with a star washer tightened well and maybe even a touch of locktite can be rock solid for many years. They just need to standardize the clips but of course in today's world of manufacturing the suits will look at every part and often save one cent per unit by going to a lesser quality part even on crucial parts like this. If they just left important parts like that alone and use a sturdy clip, placed it a bit closer to the outer edge and used a shallower cup, that would end all issues with the design.
    Personally i don't like the electrosocket and no longer use them unless necassary, but they are a good solution in some cases. Lately i have been using stock jack cups rather then changing them out to electrosockets and making sure theres a single star washer, (more then one will probably not allow for angle plugs) using a pure tone jack both because the sleeve is long enough to protrude far enough that i can use an angle plug and they hold the plug super tight. Then i tighten it with a power driver and a proper size socket and crank the torque on the driver way up. So far no issues at all. I have seen some clips tho that are so flimsy i would not trust them and rather use a electrosocket. But otherwise i now prefer to stay stock when possible.
    unixfish, yegbert and Boreas like this.
  4. SixgunElectric
    SixgunElectric TDPRI Member
    Electrosocket really IS the only way to go!
  5. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    I agree. One thing about the True Tone socket (very solid/strong connection) is that if you DON'T couple it with an Electrosocket, it is very likely to eventually loosen and rip-out a perfectly good socket mount. Some people think they are defective until they realize it is a 2-click engagement! Ask me how I know.... I prefer the FEEL of the Switchcraft Dual Contact jack and it is less likely to tear out a good mount. One good click and done!
  6. Sax-son
    Sax-son Tele-Holic
    Three Rivers, CA
    I have electro sockets on all my telecasters. It's much easier to deal with.
