Si, what should I do with my Squier Affinity BSB tele?
Discussion in 'Telecaster Discussion Forum' started by Chappy, Jan 6, 2010.
  1. Chappy
    Chappy NEW MEMBER!
    I scored a Squier Affinity tele in Butterscotch Blonde a few months ago for 100 bucks but I dont know what to do with it..I wanted to put a humbucker in the neck position and possible tint the neck or replace it with a fatter one. Im not sure what else though electronics wise. It has a couple dings so its got a little relic thing going.
    Any recommendations?
    Thank in advance..
  2. originalmatthew
    originalmatthew Tele-Holic
    Riverside, California
    If it were mine, I would do a mini- humbucker in the neck and add a push/pull tone pot so I could coil split the humbucker. I would add a treble bleed mod on the volume pot if it doesn't have one.
  3. playcaster
    playcaster Tele-Meister
    europe
    The neck seems replaceable with a nashville type
  4. aunchaki
    aunchaki Friend of Leo's
    Central New York
    Try the neck for a bit. Mine's nice and chunky. I tinted it, so it wasn't so white, but I'm happy with the feel of it.
  5. monfoodoo
    monfoodoo Tele-Holic
    baltimore,md
    I,d turn it into an Esquire.Thats the plan here when i get one.soon
  6. Worn
    Worn Tele-Holic
    Toronto
    If you want a humbucker in the neck, try a GFS Lil Puncher dual rail pickup. I have a pair of them in a Pinecaster and I'm very happy with them.
    You could replace the pots with full size pots and a Sprague cap. If I remember correctly, the control rout is not cut deep enough to fit a US switch without some routing.
    The neck isn't bad at all, give it some time to get used to it.
  7. Five-O
    Five-O Tele-Afflicted
    Huntsville, AL.
    Drill the body for string thru, add vintage tuners, a vintage bridge with brass saddles, and replace the nut with a bone one, and replace the neck pickup with something a little better, the bridge pickup ain't too bad and you will then have one fine Tele..
  8. maccampbells
    maccampbells Tele-Meister
    Kalamazoo, Michigan
    play it!
  9. Chappy
    Chappy NEW MEMBER!
    Thanks guys for the tips..Im going to do most if not all of the above. I'll definitely check out the GFS pickup for the neck..
  10. playcaster
    europe
    I thought you replaced the neck on your BSB squier
  11. Twang_Newbie
    Twang_Newbie TDPRI Member
    St. Pete, FL
    I too just bought a BSB Affinity. It is my first Tele. (Love'in it):p
    I'm putting in a SD Little '59 tomorrow.
    I just got some string thru body string ferrels. I noticed that the stock "semi-heavy-mass" bridge has no holes in the base for the strings, only out the back.
    Should i just drill them in, or replace the bridge?
    Thanks..
  12. playcaster
    europe
    Congrats :p
    I think what people tend to do here is replace the bridge with a 3 saddle ashtray type.
    I've only replaced the saddles on mine with the graphtech 6 saddles.
  13. Xanderbeanz
    Xanderbeanz TDPRI Member
    Birmingham, UK
    i did this to mine:
    sanded it, got a car spraying technician to spray it honda pink, whacked in a stacked humbucker in the bridge and bought a 3ply esquier pick guard and some black knobs...
    ...you may prefer to spray yours a more manly colour XD
    total cost <£100 excluding labour
