ReIgnition
First update to my pedalboard since 2015 or so.... note there's a buffer after the Fuzz.
Very nice! I play sitting down at church and having everything up at “adjustment level “ would be sweet! As an added bonus it would keep the singers from backing up onto my floor board.First actual pedal board. Be Kind!
For me it's all about 'building the actual board and using it in
'table top
JM
This looks great. You use the same SD-1 settings as me--level 10, drive 0. These pedals might do fine with a daisy chain power supply. With four analog pedals without unusual polarities or voltages, the OneSpot daisy chain power supply would probably be fine. If you were looking for something isolated, I have an MXR Iso-Brick Mini that I use under a Pedaltrain Nano+ board.Finally….. my first pedalboard!
Pedaltrain Nano+: (OD1) Boss SD-1 > (OD2) Ibanez TS808 > (tremolo) Carl Martin Surf Trem > (delay) MXR Carbon Copy
Next steps:
1 - practice, practice, practice & practice, I want to know/try everything for every single effect and mixing together
2 - add a power supply, something like the Volto (battery type)
3 - add in the future a Fuzz/distorsor (replacing the tremolo with one standard size or removing the SD-1).
Man I think your board looks great! I would suggest the Trutone CS6 for power. It will fit under your board, be clean and isolated, plus it gives you 12 and 18 volt options if your power needs ever change down the line.Finally….. my first pedalboard!
Next steps:
yes I think is an excellent boost for the TS...You use the same SD-1 settings as me--level 10, drive 0
I dig this tidy little setup.New Nano+ for light gigs at tiny venues playing mostly grunge covers, put together with what was lying around aside from the board itself. Powered underneath by a Cioks DC5. And before I get scorn for using the Korg tuner instead of a TU-2 have this one around because I use the strobe mode for guitar setups.
The Iridium might be overkill but it's what I have on hand that gives amp and IR modelling easiest for what I need here. The CE-5 is almost 30 years old now, so analog, and the TR-2 is 25. The DS-1 I have no idea what age or version this one is, I think I found it in a gutter or the woods or something as usual for DS-1s.
The best part is that it's ampless and Pedaltrains come with a great soft case so all I need to haul around is a gigbag and this little board.I dig this tidy little setup.
