Show us your Pedal board.
Discussion in 'The Stomp Box' started by Twangbanger, Aug 23, 2006.
  1. TheRumRunner
    TheRumRunner Tele-Afflicted
    TheGreatWhiteNorth
    This...
    Into this...
    DW
    Rezblues, pokett, chesire and 3 others like this.
  2. TheRumRunner
    TheGreatWhiteNorth
    Getting delayed
    And one DMM goes here
    I think I was lost in Space.
    DW
  3. TheRumRunner
    TheGreatWhiteNorth
    My daughter bedazzled a Silver Pony I made, it replaced the Soul Food on my big board
    DW
  4. AdamL
    AdamL TDPRI Member
    In order: Polytune > Dynacomp > Pitchfork (+Expression pedal) > Catalyst > Micro Vibe > OCD > Phasor > Envelope Filter > Trelicopter > front of Traynor YGL1 combo amp. Effects loop: Carbon Copy > Seraphim > Ditto > back to amp. All connected by Lava Piston cables. All powered by V Labs Power Plus 2 and a few splitter cords. The Seraphim is the only buffered bypass pedal. I wonder if a buffer pedal would help in front of the amp? All connecting cords total 50 ft.
    Thanks for the advice on setup!
  5. BBill64
    BBill64 Tele-Afflicted
    United Kingdom
    TRR, you're an example for us all to follow.
    And this is a good lookin' stomp.
    pokett and TheRumRunner like this.
  6. TelePrankster
    TelePrankster Tele-Meister
    Rome
    Love that RE-301!
    TheRumRunner likes this.
  7. Hollandcaster
    Hollandcaster Tele-Holic
    Wagenberg, Holland
    Went back to a Xotic ACplus
    guitarguy97 and RetroTeleRod like this.
  8. blowery
    blowery Tele-Meister
    CO
    Just updated. Lots of dirt, probably too much, lots of options and the Ethos gives me direct/speaker sim as I play direct half the time. Also the DD20/Flint give me stereo out direct if I wanted too.
    iowa and SolidSteak like this.
  9. SolidSteak
    SolidSteak Friend of Leo's
    Really nice artwork! Hope there's some kind of spray sealer or something on it? Amazing design.
  10. tele_pathic
    tele_pathic Friend of Leo's
    St. George, UT
    Oh man, how do you like that SA KM Fuzz? I've been eyeballing one just for the versatility of what it does.
  11. SolidSteak
    I have a Tone Block 200 and I know they were built so they can go right on the pedal board but I just seem to like mine sitting on top of a 2x12. Maybe I'll have to try it though since both my pedal boards are only like 2-4 items each. Speaking of which I need to get pictures.
  12. blowery
    CO
    I really like that pedal. It has a bunch of great options for sure. I have been experimenting with a couple of the presets loaded online and they are pretty good. I like the stock fuzz face and the Big Muff is a really nice tone. There are so many options with routing, dual drives/stacking, parallel, stereo switchable with a favorite switch I have barely touched the surface on it.
    Right now they are working on a Klon engine so that might be really good pushing into my Ethos ODS...if it were a real Klon into a Real Dumble, the apocalypse could be warded off by that mighty tone.:rolleyes:
    Overall great pedal with really good sounds and flexible but pretty dang easy to use.
    Right now I have the 3 stock presets, plus higher Gain TS9, A clean boost and a low gain setting.
  13. blowery
    CO
    Yeah it works great on that setup especially when I play where we have the cab off of the stage or a long ways away. Just a quick reach down to change anything. It's setup great as I only need 1 power cord, 1 guitar in and 1 speaker out and I'm done. Setup and teardown is really easy even with pedals in the loop. The voodoo labs powers the Mini 101.
  14. DannyStereo
    DannyStereo Poster Extraordinaire
    Kelso, Washington
    Posted this on the 'Worship Boards' as well:
    I sold off my Germanium Muff and bought a true bypass looper. It's a Loop Master brand with 5 loops and a tuner out. I'm currently borrowing my friend's Ego Comp.
    Signal as follows:
    Guitar>Ego Comp>Volume Pedal>Jetter Jet Drive>Barber Direct Drive Compact>OCD>Fatboost>looper in -
    Loop 1: Empress Tremolo
    Loop 2: Joyo American Sound (for direct in amp sim)
    Loop 3: Way Huge Supa Puss
    Loop 4: TC Alter Ego x4
    Loop 5: Strymon blueSky
    Looper out> Boss TU-2>amp [​IMG]
    Current guitar list:
    * Gretsch 5420t
    * Gibson Les Paul Studio
    * Gibson Les Paul Classic
    Current Amp List:
    Fender Twin Amp
    Supro Thunderbolt Plus
    Bad Cat Classic Cat
    Hollandcaster, RetroTeleRod and Seba like this.
  15. TheRumRunner
    TheGreatWhiteNorth
    I did the raw enclosure in 3 coats of sparkly silver, she did the art work and then I put a coat of clear over it. It took some testing as she used a very fine permanent artist marker and I had to find a clear that would not make the ink run. I used a cheapo rattle can spray. thx
  16. Cicada Nation
    Cicada Nation Tele-Meister
    Northern Virginia
    And here is the backup board for just messing around with the Pro Jr. (Requires reverb):
    DakotaRed likes this.
  17. Nasty
    Nasty Tele-Meister
    vallejo ca
    You can kind of see it at the lower left
  18. bottlenecker
    bottlenecker Friend of Leo's
    Wisconsin
    Each loop has a single pedal in it? Aren't those pedals true bypass?
  19. DannyStereo
    Kelso, Washington
    Yes, but I found that by taking them out of the signal loop unless I'm using them, I'm getting less noise and my tone is a little stronger going clean. Believe it or not, it's made a pretty big difference.
  20. fenderguy72
    fenderguy72 Tele-Meister
    Saskatchewan, Canada
    A pic of my lil jam board. Lighter then my other PT1 board.
    teletimetx likes this.
