Show us your Pedal board.
Discussion in 'The Stomp Box' started by Twangbanger, Aug 23, 2006.
  1. seventyeight
    seventyeight Tele-Meister
    Dublin, IRE
    True, except USPS charges $45 to deliver to here so mine is cheaper :)
  2. Mr Quiet You
    Mr Quiet You TDPRI Member
    London
    2nd Post, here's my pedalboard. Has taken me a little while to get it how I like it. Famous last words but I'm not planning any new purchases for a while! However one potential addition is a DIY clean boost to offset the volume loss on the Tremolo, just need to get around to making it.
    Running from left to right:
    TC Electronic Polytune
    Germanium Fuzz Face Clone
    Rehoused Danelectro V1 Drive and Transparent Overdrive
    Boss SD-1 (C6 removed)
    Colorsound Tremolo
    TC Electronic Flashback Delay
  3. valvestate
    valvestate Tele-Afflicted
    Land of the Merlion
    wow... where and how much did it cost you for that Danelectro rehousing?
  4. Mr Quiet You
    London
    It was done by a UK based company called Stone Box Audio and cost in the region of £80, if memory serves me. Had enough of the knob placement on the Danelectro versions. Love the sound of these two pedals and figured the expense was less than sourcing the originals that these two are based on.
    http://www.stoneboxaudio.co.uk/
    No affiliation but was very satisfied with the result and the customer service.
  5. Logieberra
    Logieberra TDPRI Member
  6. brianwoo903
    brianwoo903 TDPRI Member
    Queens, NY
    thinking on adding an mxr octave bass deluxe to mix complete the mix.
  7. valvestate
    Land of the Merlion
    thanks for responding! it really does look good... i also have the version 1 of Drice and Transparent OD, they do sound great in live band!
  8. jacksongls
    jacksongls NEW MEMBER!
    Austin
    Switch through a 72 tele thinline, lap steel and resonator using the line selector. Then pretty much all durham pedals plus DL4 and volume pedal. Goin into a blues jr w cannibis Rex or fender super. Love my durham pedals.
  9. kromanomo
    kromanomo Tele-Afflicted
    Brooklyn, NYC
    Still playing around with the order of the dirt pedals. I built a shelf so its easier to mess with the settings while playing. I'd like to add a good trem, a digital delay, a looper, and maybe get a different distortion. Honestly, I could live without the Phase 90 - need something much more subtle.
    R to L - Guitar into AstroTone on through to the Chicklet on the other side - into a '78 Champ.
  10. ledfloyd
    ledfloyd TDPRI Member
    New Westminster, BC
    What a mess! I'm going to make custom power cables that will go thru the screen to make it look less like a string of Christmas lights. The bare metal box is an A/B and TB switcher with the SFT and RAH in each loop. The gray/blue pedal is a Marrs Pedals Collide-O-Scope it's a single loop blender for the Philosopher's Tone ( the blend control on the PT is near useless )
  11. Logieberra
    hey man mines big and messy too, functional is what matters.. you like the RAH? I thought it was too middy and muddy or something so I sold it and got a Devi Ever Zero good and malekko spring... best move I ever made the zero good stacked with my other fuzzes or drives creates this amp on the verge of crumbling endless sputter sustain sound its great !
  12. ledfloyd
    New Westminster, BC
    The RAH is great. Middy for sure. Muddy? Not to my ears. I do run it with the bass below noon and the mids at 4-5 o'clock though. The SFT handles all the lower bassy-muddy-gainy tones.
  13. Logieberra
    ahh maybe it was just the way it was through my rig but I found it not clear enough for my needs but to each their own.. great looking board nonetheless!
  14. TieDyedDevil
    TieDyedDevil Tele-Holic
    Portland, OR
    That's kind of cool, actually... :cool:
    I like that you can use hardware fasteners to hold down the pedals. Is there any reason you can't just run a slightly longer screw from the back of the board and back it with a washer?
    Did you build the frame yourself or repurpose it from somewhere else?
    (Did I mention that's a cool design...? I'm tempted to copy it for my next board. ;))
    Personally, I wouldn't bother with running custom cables through the board; I'd just route the cables neatly on top of the board and use zip-ties to hold them in place.
  15. ledfloyd
    New Westminster, BC
    I found screw lengths as well as hole depths differed quite a bit from enclosure to enclosure and didn't want to deal with several different length screws. It would have been simpler and cleaner looking in the end but kind of a PitA to sort out.
    The frame is from Ikea. It's a shelf from the Broder shelving system. It's basically a metal Gorm.
    I already have the DC jacks and 22g 2con wire. I really have to do something different than what I have now, too many short extensions and spitters with 1/2 of the daisy-chain plugs unused since they don't reach
  16. Obsessed
    Montana
    Finally took a pic of my board.
    Since you guys have given me gas, talkin' about great pedals, I've been trying to find some real estate. So, I finally took a photo. Basically the LS-2 switches to my rhythm loop: Fish and Chips EQ > BLT slap echo > looper > amp. Main loop is: Vox V810 > Blues Pro > EQ > Trem > FRV-1 > Echo > Looper > amp. The Boss momentary switch runs to my old CD guitar trainer or porta studio, mounted below my music stand on that silver pole sticking up. That knob just below the Trem, releases the whole hinged, second tier, up for cable access. Whole thing built with 3/8 plywood including the hinged top. Yeah, feels like moving an average amp. Love the Fender volume pedal, but it weighs a ton. Last time I made a change was to swap out a double wide Rockton Trem for the Rogue Trem (MF - SDotD), so that I could add the MI Audio Blues Pro (w/ Fuzz switch). Except for Blues Pro and Trem, everything else bought used on eBay.
  17. telefan62
    telefan62 Tele-Meister
    Silicon Valley, CA
    I wired up a new experiment this weekend:
    Took my M9 out of mothballs and re-jiggered my board to accommodate it. I don't like the way a lot of the Line6 stuff sounds - especially the dirt - but the Trem, Phaser, Auto-Wah, DDL, etc. are kind of cool, so I'm going to try incorporating some of that stuff into my playing and see if I like it.
    Signal chain is now:
    Tele or Les Paul ->
    Polytune Mini ->
    OCD (for solo boost) ->
    Formula #5 / SFT / DLS depending on the guitar/song ->
    Xotic EP Booster (boost @ 10 o'clock for Telecaster; 0db for Les Paul) ->
    Line6 for modulations and such ->
    Carbon Copy ->
    Amp
    Playing around with this setup yesterday yielded some pretty cool tones, definitely outside my normal OD->Delay setup. Looking forward to next rehearsal...
  18. Logieberra
    nice compact board... me likey!
  19. tonedreamer
    tonedreamer Tele-Holic
    Myrtle Creek, Oregon
    Just added the Sovereign, and it is awesome!
  20. TieDyedDevil
    Portland, OR
    Thank you for the info!
