And there is at least a partial answer. Direct sun is never good.Your Rustoleum finish looks nice! I think I'll use some other scrap I have to give that a test as well.
Maybe I shouldn't have sprayed my paint out in the sun...
Hmm. You know, I think I would mask off those test pieces in a few sections and just experiment. I'd probably go 600 grit wet sand on one (which is where I think I'd start) and use a more aggressive 400 grit wet sand on another panel to see if you can get away with it. Try to find a sanding motion that is repeatable and not something where you are bearing down on the test piece with any real force -- just the sandpaper. I'd probably use a felt pad or some cork and not something hard and unyielding as a backer on the sandpaper (don't use your fingers or your hand, that will give unpredictable results). Wet sanding keeps the sandpaper from clogging so you are getting consistent grit strength during the sanding operation. This is final level sanding.To sand my current coat smooth, what grit should I use, and should I wet or dry sand it?
My only experience is with nitro cellulose lacquer and I sand to 320 or 400 dry between sets of three coats. That is enough to remove scratches, orange peel and other flaws and leaves a little tooth for the next coat to melt into. A professional finisher would not have to do any sanding between coats but I'm not a pro.To sand my current coat smooth, what grit should I use, and should I wet or dry sand it?
100% this, and heat the can. Never spray in direct sunlight, the mist drying too fast before it hits the object is a huge cause of orange peel and why a decent reflective wet coat helps.Laying on an even, wet coat (takes practice) will allow the finish to self-level. The hard part is getting even coverage and working fast.
It makes it easier to do if you have multiple overhead bright lights and monitor your coverage by watching the reflection of those lights in the wet finish as you lay it on.
As soon as you see a mirror-like reflection, you're done applying finish there; move to areas with no/partial reflection. If you go too heavy, you'll get runs.
It's a very very fine line between too little and too much.
Trying cutting the last heavy coat back to two more thin coats. I think it's the thick coat that is not flowing out. Orange peel is very common, and how you deal with it is to wet sand it out.Currently using some scrap yellow poplar for practicing my spray painting for a poplar body: sealed one side with Zpoxy and the other with Solarez polyester, hit both with 3 coats of gray sandable Duplicolor Primer, waited a day then did 3 coats of Universal White Duplicolor; 2 light coats 10 minutes apart for each and 1 heavier coat which I let dry for a day.
Coming back to it I thought I'd be able to get a smooth gloss finish for clear coat, but unfortunately both sides have orange peel to them. Is this something that every spray paint just has, or do I need to change my painting technique to avoid it? Also, can I sand it with 800 and spray over it again?
I’d sand / steel wool and spray again.Currently using some scrap yellow poplar for practicing my spray painting for a poplar body: sealed one side with Zpoxy and the other with Solarez polyester, hit both with 3 coats of gray sandable Duplicolor Primer, waited a day then did 3 coats of Universal White Duplicolor; 2 light coats 10 minutes apart for each and 1 heavier coat which I let dry for a day.
You don’t wet sand until the wood is fully encapsulated with primer or finish. If you’re wet sanding through your finish into the wood, you don’t have enough finish on it or just don’t know when to stop sanding.Nobody has mentioned what to use when wet sanding. Don’t use water! Use naphtha or mineral spirits, because water will swell the wood grain. When you sand on these swollen areas, after the wood dries and contracts, you’ll have a rut in the surface.
Why are you using primer after ZPoxy or Poly? I have used Zinsser primer, sanded it and sprayed house paint and it didn't have orange peel.Currently using some scrap yellow poplar for practicing my spray painting for a poplar body: sealed one side with Zpoxy and the other with Solarez polyester, hit both with 3 coats of gray sandable Duplicolor Primer, waited a day then did 3 coats of Universal White Duplicolor; 2 light coats 10 minutes apart for each and 1 heavier coat which I let dry for a day.
Absolutely on target I think. Very, very light sanding with the coarser grits will help prevent scratches that go too deep to come out. Wet sanding with 2000 grit and then even polishing should put your project right where you want it. Best of luck to you!I always sand between coats, let all coats completely dry, hit the final coat with up to 2000 grit, polish, wax.
