Should I get an Electrosocket?
Discussion in 'Telecaster Discussion Forum' started by TokyoPortrait, Aug 4, 2021.
  1. TokyoPortrait
    TokyoPortrait Friend of Leo's
    Tokyo, Japan
    Hi.
    Came into my study just before and found these lying on the floor… :rolleyes:
    Pax/
    Dean
  2. Boreas
    Boreas Poster Extraordinaire Silver Supporter
    Adirondack Coast, NY
    If you weren't having trouble, I would just screw it back in. If you gig - replace it.
    Tonetele, Roscoe295, bls82261 and 3 others like this.
  3. superbadj
    superbadj Poster Extraordinaire
    roanoke, va
    I've replaced all 8 of my tele sockets w/electrosockets, so yeah, I'm voting yes.
    But you do you.
    To me, that original design just sucks, and will always come loose. The ES solves it and it's cheap enough. Why wouldn't you fix it? Unless it's just a collector tele in original condition (in which case I'd ask why even own it then)....replace it.
    Ronzo, Amishius, bluesguy62 and 13 others like this.
  4. Dan German
    Dan German Doctor of Teleocity
    Left of the Left Coast
    Were it me, I would use this as an excuse to install an Electrosocket.
    Vibroluxer, zippofan, Ronzo and 7 others like this.
  5. TokyoPortrait
    Tokyo, Japan
    Hi.
    Turns out, I can't find a proper Electorsocket at all here. Not in my online searches anyway. Maybe it gets called something odd here?
    So, out with the long nose. And screwdriver. And pencil. And curses...
    Pax/
    Dean
  6. Killing Floor
    Killing Floor Friend of Leo's
    Austin, TX
    In would not leave that on the floor. You might step on it. That would hurt. Also, Fenders are wonderful but Leo made some mistakes and his Tele jack is one of them. My thought is that if you can count something among the first changes he made in his next venture it is at least fair to say he recognized it needed amendment.
    Update it.
    TokyoPortrait likes this.
  7. Fenderbaum
    Fenderbaum Tele-Meister
    Bergen, Norway
    Seems like they are called "Retrofit Jackplate" of all things. Dunno what part of it is "Retro"
    Anyways.. Look here AP-5270-001 | Allparts® Music Corp
  8. Boreas
    I find it less frustrating to remove the control plate and poosh from the back. Then simply use a socket wrench to carefully tighten the bejeezus out of it. Don't let the socket spin - it should have a toothed washer front and back. Consider some blue LocTite or fingernail polish (color choice is yours).
    I have only had trouble with one where the metal thingie dislodged from the wood - likely improper install/repair. Those are the ones I usually replace with Electrodockets. Once the wood is chewed up inside, they become more problematic.
  9. SnidelyWhiplash
    SnidelyWhiplash Friend of Leo's
    Hoggtown, KY.
    I have a tele with the original style jack & it has worked flawlessly.
    I have one with a ES & the nut kept coming loose, so i used a drop
    of CA glue to hold it in place.
    Ronzo, moosie, bicaster and 2 others like this.
  10. Zoso420
    Zoso420 Tele-Meister
    Chicago
  11. Alamo
    Alamo Doctor of Teleocity
    Berlin
    maybe it was a grand idea...for five minutes:twisted:
  12. El Tele Lobo
    El Tele Lobo Poster Extraordinaire
    I put them on all my telecasters…along with 4-way switches. Leo didn’t get everything right the first time.
    5haun, Edgebound, MarkSieber and 4 others like this.
  13. Fendereedo
    Fendereedo Poster Extraordinaire
    Sunny Suffolk UK
    There are 2 fit types. One is metric = far East.
    And imperial = USA and Mexico made.
    telemnemonics and Alamo like this.
  14. TokyoPortrait
    Tokyo, Japan
    Hi.
    Sweet, thanks.
    Pax/
    Dean
  15. Nick Fanis
    Athens-GREECE
    Ebay is chock-full of ES
  16. Alamo
    Berlin
    I just replaced the dreaded cup on new CV70's Tele with a metric ES.
    no soldering was needed. as easy as screwing in a light bulb.
    Fendereedo and TokyoPortrait like this.
  17. Controller
    Controller Friend of Leo's Silver Supporter
    Montana
    Never had a problem with the original, but it's an easy fix.
  18. beanluc
    beanluc Tele-Afflicted
    California Bay Area
    Retrofit means replace, reinforce and/or upgrade, they’re not talking about retro as a matter of style.
    And if I’m not mistaken, Electrosocket is a trademarked name though the design itself isn’t trademarked, patented, copyrighted or otherwise license-controlled, so, there are a variety of makes and models besides the Electrosocket.
  19. TokyoPortrait
    Tokyo, Japan
    Hi.
    Yep, I like "retro-," as a prefix. You can think of it as meaning behind or back (cf. post-). As in retrograde - to grade (i.e. go/step) back, rather than 'up.' Which makes it a little problematic in retrofit, I feel. I don't think it truly means 'after.' Usage rules, I guess.
    Anyway, my original post was more 'rolls eyes' at the sudden appearance of the cup assembly on my floor than anything.
    I've decided to try to fix it. I was about to hit 'buy,' when I realised I was gassing. So, I hit the brakes on that. Let need, not greed dictate I say.
    I hope I won't regret this decision, in retrospect...
    Pax/
    Dean
  20. NC E30
    NC E30 Tele-Meister
    North Carolina
    It's a good excuse to switch, but it looks as if the nut just loosened up and fell off. Easily fixable. The other advantage to an electro socket is that it opens up the variety of 90º cables you can use.
    zippofan, Ronzo, Bluesbob and 3 others like this.
