Should I cover my workbench with carpet?
Poll: Should I cover my workbench with carpet?
  • Yes
    Votes: 7 15.2%
  • No
    Votes: 39 84.8%
  • Total voters
    46
TheGoodTexan
Nashville, TN
Today's meaningless question. Should I cover my workbench with carpet?
I'm making a new top for my workbench, which stays in the garage. The old top was the original, which was a formica-type thing glued to cheap MDF. The moisture got to it and the wood swelled, and formica started lifting on the edges... got really sharp in places, and "bubbly" in other areas. So I got a new piece of better quality MDF (had to special order it actually), and rounded over the front and side edges with a router, and sealed it tight with a Minwax product and some spray shellac on the edges (as much as it would soak up). I lightly sanded it all flat. Then, just for fun... I took some polishing compound and some 0000 steel wool and polished up an area - which looked so nice and shiny! haha..
But I got to thinking... maybe I should cover the top in some ozite-type carpet... sort of a backless shop carpet... just for some extra protection? I've used it before over raw MDF and it does a decent job. Or just leave it uncovered... and polish the top as previously described?
The work bench is where I do most of my guitar work, with one of those old StewMac guitar pads with the neck cradle. I do soldering there. Work on electronics. Speakers. Dremel type stuff.
Danb541
Oregon
i use whatever but carpet isn't my favorite. Lately Ive been using a floor mat runner from lowes. its sort of a carpet material but really short.
brookdalebill
Tele Axpert
Austin, Tx
I would not. Too much stuff would get lodged in there, like metal shavings etc. that could scratch a guitar set on there.
Solder, too.
Didn't even think of that. That answers it.
I do set ups and minor repairs at my Wednesday day job.
I use steel wool to clean fingerboards and frets.
I mask off the pickups (if there are any), and do that work a considerable distance from my workbench/solder station.
That workbench has a rubber mat.
King Fan
Salt Lake City
+1 on all the (wow, so many) good reasons not to use carpet.
To double down on the solder thing: most folks worry about the fumes -- but fumes don't carry lead, just flux smoke, which is 'only' a respiratory irritant. It's the lead spatter / crumbs / microdrop dust that's toxic -- the Brits call it 'dross'. This stuff is what gives you lead poisoning, it's why we're told not to eat or drink around soldering, and why we wash our hands when we're done. And carpet is the perfect place to stockpile it and get exposed to it.
KokoTele
Vendor Member
albany, ny [not chicago]
I've wanted yoga mats to work, but the ones that will stay put have too much friction on the surface and will stick to a nitro-finished guitar if you let it sit overnight.
Target sells these big neoprene kitchen floor mats for $24 that are essentially big mouse pads. They have a fabric covering with no pile so you can sweep dust and debris away, and mostly stay put on the bench. If I could avoid dripping glue on them, they'd last me forever. As it is, I get a couple of years out of one before I need to replace it.
New Posts
