Shopping for a baby amp
Discussion in 'Amp Central Station' started by Mr Perch, Aug 17, 2020.
  1. dcos
    dcos Tele-Meister
    Sand Lake, Michigan
    All my amps fall in this genre. Fender Champion 40, Vox AC10C1, Blues Junior, Quilter Toneblock 45. They all would probably work for you, but the best jazz tones would be the Quilter. SS, but very warm natural tones without the high kind of irritating high end jangle that can come out of all the others. It's very small, I keep it on my pedal board, you can run an external cab or just pump it through the PA or monitors, which is what I do at rehearsals.
  2. Skyscraper1952
    Skyscraper1952 TDPRI Member
    Queens, NYC
    My Roland Cube EX is 50 watts of A/C or battery powered goodness. At our last jam I was asked to turn down the volume as it was drowning out my friends AC30. Sounds good with both my acoustic and electric guitars.
  3. Zoot Zoot
    Zoot Zoot TDPRI Member
    Laney LC15 (or LC15R) - great tone, loud enough and the valves will keep you warm in the winter. They're so good that I bought another one, initially as a spare but now run both at once. They can be found cheap too! (but get one quick before people wake up and start calling them a 'classic')
    kookaburra likes this.
  4. Arafel
    Arafel Tele-Meister
    Denver
    My Swart AST Jr. can (5 watts with an 8-inch speaker). I just have to accept that I won't have any clean tone. I'd recommend it to the OP but it's likely out of his price range
  5. gitapik
    gitapik Tele-Afflicted Gold Supporter
    New York City
    +1
    And the MicroPro is anything but sterile. My 8" is only 19 lbs and covers a lot of territory. I was set to buy the Aviator, but was fortunate to run into some unexpected funds, so I got the MicroPro.
    If you're looking for good tone that won't break up (unless you want it to) at higher volumes, in a lightweight package; my rec is a Quilter.
  6. Beachbum
    Beachbum Friend of Leo's
    Sand Land
    +1
    Treynor and Timmay like this.
  7. bettyseldest
    bettyseldest Friend of Leo's
    I have two, both bought for less than £90. I have often gigged one without running it through the PA.
    Zoot Zoot likes this.
  8. 11 Gauge
    11 Gauge Doctor of Teleocity
    Near BWI Int'l
    I have a Quilter 101 Mini that I used to use with a 1X12 cab, and it was perfect for just cleans. I put the same Celestion bass 12 neo that Quilter uses for their 'heavy duty' setups, and it's nearly mind-blowing just how loud such a portable, lightweight amp setup can be.
    ...The caveat with the v1 101 Mini was their unusual and slightly unorthodox tone controls, but again, IME, perfect for cleans, especially WARM cleans (there's a tone knob to roll off the top end).
    If I never needed overdriven tones, I'd never have any desire to look beyond the 101 Mini as the perfect gigging clean machine. With the right reverb pedal, it really was like a portable, Mini Me version of a Twin Reverb, to my ears.
    ...It's also the warm clean capabilities of the 101 Mini that have me keeping it, even if I'm not currently using it.
    BB likes this.
  9. Jay Jernigan
    Jay Jernigan Tele-Holic
    10-uh-C
    I know from experience that the Quilter amps are loud and clean. This experience has been with someone else using one. I can't advise as per the market.
    New: I have some familiarity with the Fender Champion 40. Good amp, clean as you want it, with some serviceable effects if you need them.
    Used: I don't know what they sell for these days but a Peavey Bandit will be heard, I'm sure. Not lightweight, really, but not much heavier than a guitar, with accessories, in a hardshell case.
    BB likes this.
  10. ayjaydee
    ayjaydee TDPRI Member
    High Wycombe, UK
    It's hard to beat the Boss Katana 50 MkII on all fronts.
    Rocky058 and Supereditor like this.
  11. Supereditor
    Supereditor TDPRI Member
    Oroville, CA
    Another vote for the Boss Katana or Fender ToneMaster series. Not as small as some you mentioned, but light, versatile and giggable. The ToneMasters are loud and do a remarkably nice job replicating the amps they are copied from. If you are worried about wattage with the 50 watt Katana, you could get the head and bring a 10-inch cab. That would require one more trip but then we’re talking really light, and the 5-inch speaker in the head is actually loud enough for some small applications.
  12. dave_t
    dave_t NEW MEMBER!
    Toronto
    If the Fender Mustang GT100 caught your eye, make sure to check out the newer GTX100. I picked one up used a couple of weeks ago, and really liking it so far. 100w solid state 12" speaker and it is SUPER LIGHT. It's lighter than the 10" SuperChamp XD tube amp that's been mentioned here (which I also own and like)
  13. Marblatx
    Marblatx TDPRI Member
    Austin
    Mustang II Dale Watson uses/used one.
  14. Cosmicstrings
    Cosmicstrings TDPRI Member
    new england
    Pro Jr. It kills cranked up at Jams.
    I cant tell you how many times good musicians with good (and heavier) gear have come up after Jams to comment on how wonderfully that amp filled the room.
    BB likes this.
  15. bblumentritt
    bblumentritt Tele-Afflicted
    Austin, Texas
    BB likes this.
  16. Mr Perch
    Mr Perch Tele-Afflicted
    los angeles
    It probably is, and I need a clean tone because the jam sessions I go to are mainly straight-ahead jazz.
    I pulled the trigger on a Mustang LT50. It should be loud enough, and I am enjoying the process of maniacally customizing the presets. It's 19 lb., not exactly tiny, but petite. Definitely a one hand carry.
    BB likes this.
  17. Mr Perch
    los angeles
    This looks like a slightly smaller, much more expensive version of my Dean Markley CD30.
  18. glyons1
    glyons1 TDPRI Member
    San Diego
  19. padreraven
    padreraven Tele-Meister
    Seattle
    You want solid state if you want to carry it a lot unless you want to bulk up while you schlep. I haven't had a lot of amps, but I have an Acoustic A40 that I like the tone on. It does a much better job (and of course has more power) than my Marshall MG15dfx which I just use in my living room now. If you're just playing clean they're nice and they're pretty cheap. The effects are a pain so don't buy one for that.
  20. Maguchi
    Maguchi Tele-Meister
    Lalaland
    A 5 watt Fender Tweed Champ reissue, or a used mid 70s Silverface Champ for about $600 would work perfect for a jam with 5 musicians. I have a 2019 Fender '65 Princeton Reverb 1x10" 15-watt Tube Combo and that amp is enough for most situations. It weighs 34 lbs., but not too heavy for me to carry from the car to the gig in one hand and my guitar in a soft case in the other hand. I carry a Shure SM57 mic and an XLR cable in my guitar soft case for the rare situations where 15 watts is not enough. A couple pedals fit easily in the gig bag or the bottom of the amp if needed.
