Ryan300000
Over the weekend, I was playing my tele through my SF Vibro Champ. There is quite a bit of buzz from the guitar, but it stops when I touch the strings. Unfortunately, I made the stupid mistake of touching a microphone while holding the strings and got the worst shock of my life. What can I do to prevent this from happening again (aside from not touching the strings and microphone at the same time)?
Some background: The amplifier has a 3-prong grounded power cord, which was installed before I got it about 12 years ago. I upgraded the guitar pups to 51 nocasters and wired it to the 50s wiring schematic (rear position is blend of both pups, middle is neck with no tone, and front is neck with volume rolled off). Before this happened, I had been wondering if the guitar was properly grounded, but the bridge pup is already grounded to the plate, right? So, as far as I know, I shouldn't have to do anything further than that like running a wire from the bridge to a pot. One note, which may have nothing or everything to do with this: When in the back position (which is primarily what I use) and adjusting the blend knob, there is some crackling noise as I turn the knob. Could that be the cause of this issue? I have been planning to re-solder those wires, but just haven't gotten to it. (If you couldn't already tell, I'm fairly knew to wiring guitars, so pardon my ignorance!)
Any advice will be appreciated!
