Boreas suggested starting a separate thread, and I guess that's what I'm doing
Post in thread 'First Time Neck Shimmer' https://www.tdpri.com/threads/first-time-neck-shimmer.1122221/post-11740331
Not really much to say now. The guitar is my 1965 Framus Atlantik 6 semi-hollow. I really like the bridge on it, if mainly for the optics; it just looks cool and matches the string pusher-downer-bar on the whammy tailpiece. It also intonates perfectly, like magic
It has two thumbwheel adjusters to adjust the action, and they were both all the way down, no way to lower the action further (neck relief is spot-on).
The action is absolutely okay and the guitar plays beautifully, but I felt there was still some wiggle room on the action, it could go lower, except the bridge was stopping that.
So it seemed the solution could be a neck shim. As in the the other thread, I've never done it and really thought it was too complicated for a dummy like me. But then that other guy said he used the top of a cereal box and someone else chimed in saying a matchbook cover would have more mojo (that's how I remember it), and I thought, what the hey, sounds like something even I could handle and the chances of destroying my guitar are negligible.
So I took off the neck (loosen strings, secure them with a capo, boom).
There was already a little shim at the front, which to my non mechanical engineering brain was doing the exact opposite of what I wanted. The guitar is coming in on 60 years of age, so who knows who did what for what reason in the past.
No problem. I just moved the little shim to the other end of the neck pocket, bolted it back together and, taa daa, the strings pretty much bottomed out on the fretboard. Remember though that the bridge was already cranked down as far as possible. So I twiddled the thumbwheels to raise the action and it feels great so far.
But I'm writing from the car while waiting for my wife at the PT. I won't have a chance to really check the difference till later. But now I do have some room to play with as far as bridge height is concerned.
The neck pocket is a lot smoother than the over-sharpened pic suggests @Boreas
The shim in the original position:
The bridge, a solid piece of machined steel:
I forgot to take a pic after moving the shim but it's just on the other side now. Might just not need it at all
