Slim Chance
I have a Vintera Modified 50s Tele with the three saddle bridge. The height of the saddles, when adjusted for correct string height and intonation rise above the strings. I would like to lower the intonation screws below the strings and if possible, lower the saddles, but still maintain the current string heights, which are at Fender spec. The B string chokes out above the 12th-14th fret, but I suspect that raising the saddle will fix it. Relief at the 8th fret is 0.008.
The question is what is the best way to fix this myself. I have tools to measure height and can adjust the truss rod as needed. I don't do fret work and will not attempt to mess with the neck pocket other than to clean it out and insert shims.
Cutting the screws would appear to be the quick fix and I can do that easily and chase the threads if needed. That, however, won't settle the saddle height issue. I should also mention that when setting up the guitar, I had to clip a few coils off of a couple of the intonation springs. The intonation is pretty good, but at least one of the saddles cannot move further back without a further reduction of spring length.
I believe that the other way to solve this problem is by inserting a shim in the neck pocket. A little more involved, but I might be able to lower the saddles and therefore the intonation screws as well. Initially, I would use card stock rather than make or purchase tapered wood shims.
I'd like your opinions and advice on how to proceed to lower the intonation screws below the strings and if possible, the saddles while maintaining the current string height.
TIA!
TIA!
