Thumper
This is where I would start on this guitarMy neck is straight - I measure the relief around .010 to .015”. I’ve rocked the whole fretboard (only frets above 12 needed a little filing) and I think I’m leveled. The action at the 12th is .070. Not very low. I’m still getting a little buzz - all frets above the 5th or so. All strings. That plinky sound like my daughter’s ukelele. I think the upper frets are the cause.
At this point I could file the frets into a fall away, or should I shim under the nut end of the heel?
Or neither? Let me know if I should provide further info.
Adjust the truss rod so the neck is dead flat and position the best long straight edge you have to see where the tops of the frets land in the bridge area. You want the edge of your ruler to be somewhere
in the middle of the vertical adjustment for the saddles.
Something I have run into, is neck pockets that are too deep or too shallow and….
aftermarket neck heels that are too thick or too thin.
Do this first before grinding on the frets,
check to see if the pocket is the correct depth and that the heel thickness of the neck is correct.
Even in the age of CNC’s there is a lot of out of spec stuff out there.
The pocket on a tele should be .625 deep and parallel to the top of the body.
The neck specs are 1” at the center of the radius, so the neck is .375 proud of the body at the back of the pocket.
