blackieNYC
My neck is straight - I measure the relief around .010 to .015”. I’ve rocked the whole fretboard (only frets above 12 needed a little filing) and I think I’m leveled. The action at the 12th is .070. Not very low. I’m still getting a little buzz - all frets above the 5th or so. All strings. That plinky sound like my daughter’s ukelele. I think the upper frets are the cause.
At this point I could file the frets into a fall away, or should I shim under the nut end of the heel?
Or neither? Let me know if I should provide further info.
