Shielding
Discussion in 'Tele Home Depot' started by Rusty Shackelford, Aug 21, 2019.
  1. Rusty Shackelford
    Rusty Shackelford TDPRI Member
    Fort Lauderdale
    I have hum that changes intensity depending on the orientation of the guitar so I'm going to install copper tape shielding throughout. I see some people on YouTube installing the shielding on the undersides of the control plate and the bridge - surely this is superfluous, correct? The thicker steel or aluminum pieces are already acting as shields. Photo grabbed from a YouTube video
  2. schmee
    schmee Poster Extraordinaire
    Yeah those are shields in effect themselves. Be sure to shield the back of the pickguard and wrap the cavity shield around the top a bit so it contacts the pickguard shield. Make sure those get grounded to the bridge ground wire and pots etc too.
    Rusty Shackelford likes this.
  3. zeedoctour
    zeedoctour Tele-Meister
    I have all single coil PU's in all 5 of my guitars. No hum issues in any of them even with plenty of gain. Here's how anal I am about shielding. :twisted:
    srvbluezz and Rusty Shackelford like this.
  4. tele_savales
    tele_savales Tele-Meister
    Brooklyn, Joey!
    Do you own your won copper mine or something? WOW!
  5. zeedoctour
    It's cheap to buy really and I don't like hum. Do it right is how I like to roll.
  6. john_cribbin
    john_cribbin Tele-Afflicted
    London
    Have you tried a different lead? Had the same problem once, tried a different lead, hum gone.
  7. 57fenderstrat
    57fenderstrat TDPRI Member
    Binghamton NY
    My strat is in the shop now getting a full foil treatment. I know it’s beaten to death if it effects tone or not but I’m getting paranoid about it, I always do when my guitar is in the shop. It’s removable if I don’t like it correct ? To the original poster good luck with yours
  8. 24 track
    kamloops bc
    make sure all of the shields are tied together and make solid contact I even shielded the jack cavity and soldered a ground wire to the body shield as for the pickup /bridge plate make sure there is continuity through out the body ( test with a multimeter ) or the feraday box will not be sealed ,I also looked for breaks and cracks in the shielding and soldered those up as well
