Shielding yes or no?
Footsore
Okay who does it and who doesn't? Is it worth it? I notice that Fender doesn't bother on the Vinteras or American Performers but uses shielding paint on the Player series?? Looking at the stripped bodies for sale on The Stratosphere ii looks like most aren't.
hopdybob
netherlands
There a two things.
1 a lot of the players are conservative. if guitars are not like from the old days with the old guitar heroes it can't be good.
so that is one reason the big guitar companies don't evolve things.
take the neck problems with gibson that snap so often, and also shielding is something were opinions differ.
but strange enough, gibson did not stop at the log op les paul, fender develop t further in materials but at one moment it seems to have stopt to.
we use better cables than our guitar heroes used, better amps, pedals, strings, but guitars?
2 we live in a world with more electronic storm surrounding us but the electronics are still old school.
if done right it does not effect your sound but benefit from the electronic storm protection.
Bill Lawrence wrote some thoughts about this subject
http://billlawrence.com/Pages/All_About_Tone.htm/TeleLovers.htm
i do all of my guitars and don't hear a change than more silent in noise.
but i use copper tape beneath and surrounding the pickups cav and alu in the control cave
why? that is mention t in the writings of Bill Lawrence ;-)
dlew919
Sydney
I was talking to an electrical engineer the other night and he felt that shielding was unnecessary.
Peegoo
Beast of Bourbon
I shield all my builds.
Even though shielding cannot guarantee quiet operation, it can often reduce noise in the signal.
A guitar's signal is fed through multiple gain stages, and an amplifier cannot differentiate between desired sound (signal) and undesired sound (noise). So it happily amplifies both of them equally.
Si G X
England
I have unshielded guitars and shielded guitars but without opening them up I couldn't tell you which was which.
There's very little to shield in my guitars anyway though, no switches and I use shielded cable to the volume pot. ... so it's only really the pickup wires and a couple of solder joints where the signal could be exposed to external noise.
Cyberi4n
Chester, Uk
Never deliberately shielded or attempted to shield any one of the 35+ guitars I've owned over the years. Played everything up to and including high gain metal/death metal live, and not once have I had a problem with excessive noise.
That's not to say others wont of course, that's just my experience.
Billy3
Charleston,Sc
If you play clean it can help the single coil hum. It can't hurt the guitar if you are trying to sell it. If you know you are going to keep that guitar for the rest of your life absolutely do it. Electric inference is an issue we all complain about. Shielding helps.
Footsore
Funny thing is the worst Tele I had for hum was an unshielded body that I put Player series pickups in. Shielded the cavities and pickguard with copper tape and it was much better. Maybe some pickups need it??
Fuggle
Georgia
My Baja had the annoying buzz that went away when I touched metal. After shielding with copper tape, the buzz seems to have left the building for good.
Killing Floor
Austin, TX
If it’s a Fender, yes, I shield it. The full cavities/routes and the pick guard. I use copper foil.
Any other brand guitar I own came factory shielded. Lots of people will give you their opinion but it’s simply a cost saving measure.
Vegetable Man
Dallas, TX
Yes, it helps. Aluminum HVAC tape from Lowes will work just fine and cover multiple guitars for less $$.
I had my doubts until I shielded a very noisy Les Paul Special with P-90's. Now I shield all of my guitars that have single coils.
Steebz Khuan
Belgium
The hum from my (unshielded) tele would drive me nuts playing quiet, clean stuff at night, especially over headphones (kids sleeping upstairs). I replaced the original (slightly overwound) pickups with Kinman zero-hums to no avail. Kinman bridge sounded terrific but I couldn't get along with the super dark neck pickup, and after a while I swapped them out for Fender CS nocaster pups and did copper shielding -- hum gone!
Stu Cazz
Spain
I had huge trouble with both my Les Paul's. Never had any clue if it was my apartment buildings wiring or if I am a too good antenna myself, fact is I had lot's of static noises and pop's. One day I even picked up a radio signal that I could tune with my guitar knobs....crazy! Tried everything, only shielding all cavities with copper tape did the trick.
Funny thing, both my mexican Fenders don't have that problem. Cavities are painted black so I may assume it's shielding paint, no tape on the inside of the pickguard's though.
schmee
Shielding yes. No doubt about it. It fixes many noises. Pickups are little antennae. The hungry little guys suck up anything they can. Put them in a cage... a Faraday cage that is......
All my solid guitars are shielded.
Happy Enchilada
Gold Supporter
God's Country
Years ago I got my MIM butterscotch Player Tele. There was a definite static sound when it was turned on, and somebody told me to rub the pickguard down with a dryer sheet ... which seemed to do the trick, but which I had to repeat every time I plugged it in. So when I swapped out the pickups for Seymour Duncan Hot Teles, I shielded it with copper tape. No more noise. Just my two cents' worth.
New Posts
