Shielded Coax Wire Choice
Discussion in 'Shock Brother's DIY Amps' started by OldPup, Apr 22, 2021.
  1. OldPup
    OldPup Tele-Meister Ad Free Member
    Charlotte, NC
    Is Coax 26AWG, Braid 7/34 Stranding okay to use in a guitar amp? I'd like to get shielded wire between the input jack and V1. Eventually, I may use it for NFB mod in a princeton reverb. But I can't figure out if this wire will work. I have already ordered it, but I am not going to install it if this is the wrong application for it. Any and all help is appreciated. Thanks.
  2. Lowerleftcoast
    california
    The AWG doesn't matter until it does. The smaller the wire, the more likely it could break due to repetitive movement.
    The outer diameter of the wire insulation becomes a factor. A large diameter is hard to route inside the chassis.
    Ime 26AWG should be fine.
    OldPup likes this.
  3. Kevin Wolfe
    Kevin Wolfe Tele-Holic
    Lakeland FL
