Shelf life for Polyester orange Drops?
Discussion in 'Shock Brother's DIY Amps' started by tubedood, Oct 8, 2020.
  1. tubedood
    tubedood Tele-Holic
    Orlando
    Hi again folks,
    I have a few dozen unused 6PS orange drops in values that are good for guitar amp builds. They test pretty spot on for the capacitance value but they are probably 12 or so years old at least.
    I don't mind buying new caps, just curious on others experience with these capacitors and if I can use 'em or if they tend to get leaky or break down.
    As always think you for your time and wisdom!
  2. Dan_Pomykalski
    Dan_Pomykalski Tele-Meister
    Madison, WI
    I don’t know if I’ve ever heard of film caps like Orange Drops going bad under normal circumstances? I’m pretty sure it’s usually the paper in oil or electrolytics that need to be replaced.
    tubedood likes this.
  3. Engine Swap
    Engine Swap Tele-Afflicted
    Chicago
    They have a 10% tolerance - do they measure outside of that? What device are you using to measure them?
  4. tubedood
    tubedood Tele-Holic
    Orlando
    The caps are unused, still in my parts drawers. I could only measure the capacitance value with my fluke dmm. They measure great as far as the values. I don't have a leakage tester.
    Thanks for any info!
  5. Lowerleftcoast
    california
    If they are NOS condition they will be good for maybe 100 years or so.
    The oldest orange drops are about 60 years old now. I would still use them.
    Damage of the orange casing would lead to problems. Other than that just use them.
    Big-ez, aging_rocker and tubedood like this.
  6. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    They don't go bad in storage unless you're storing them in an oven where they get past about 200F ;)
    tubedood and aging_rocker like this.
  7. printer2
    They will outlive you.
  8. Paul G.
    Paul G. Friend of Leo's
    Rhode Island
    The reason electrolytic caps have a shelf life is because there is a paper insulator is soaked with a liquid electrolyte. The liquid can leak or dry out and paper is paper. The reason paper in oil caps have a shelf life is because the paper insulator is soaked in oil. The oil can leak or break down and paper is paper. Orange drops have an insulator made of polyester which will be unchanged long after all life on earth is gone.
    tubedood and MLHull like this.
