Share Your Best Guidance About Routers and Routing
Discussion in 'Tele Home Depot' started by ChicknPickn, Sep 16, 2021.
  1. ChicknPickn
    ChicknPickn Tele-Afflicted Silver Supporter
    Ole Virginny
    I've just picked up a router for the first time in 10 years. The first thing I did was route out the traditional neck pocket of a pine body to accommodate a humbucker.
    I have to say that when I turned on the motor, I was reminded of a couple of incidents from way back. In one case, a slab of ash flew across the room and put a dent in a metal garage door. Another time, I tipped over a trim router and the bit came within an inch or so of my palm. I've caught myself once or twice starting to adjust the bit depth without unplugging the beast.
    Having said that, I thought that some of our skilled router users might share their Top Five, or even Top 10 tips about using these powerful tools. I'd never used one before coming to TDPRI, and I'd certainly never had any lessons.
  2. mkdaws32
    mkdaws32 Friend of Leo's Gold Supporter
    Moncton, NB Canada
    As a novice router user, I’m watching this thread with interest!
  3. Novatuc
    Novatuc Tele-Meister
    Be careful, they can ruin your day quickly. One thing I do to make routing safer is I use a foot pedal switch to start and stop, then I can have both hands on the machine when I turn it on.
  4. Bob J
    Bob J Tele-Holic
    Portland OR
    1. After you have stopped your cut, don’t move or let go of the router until it has stopped spinning.
    2. Make sure it is switched off when you attach power
    3. Disconnect from power every time you make an adjustment
  5. guitarbuilder
    You should read the list of router safety rules and keep both hands on the router.
    Safety Tips for your Router (woodcraft.com)
    Make sure your work is secure to your work bench.
    Wear Safety eyewear and a dust mask.
    Keep fingers away from the bit.
    Unplug when changing bits and making depth adjustments.
    Don't try and do stuff you know is risky.
    Hog out the wood with a drill press and clean up with the router if you can.
    Buy good quality bits as you get what you pay for with router bits. Think Whiteside!
    Avoid climb milling.
    Make or buy a router table.
    Read this thread:
    Let's make a body ! | Telecaster Guitar Forum (tdpri.com)
    ChicknPickn, Archtops, natec and 3 others like this.
  6. Mjea80
    Mjea80 Tele-Meister
    Ontario
    +1 for not taking your hands off the router until the bit has stopped.
    The slightest move when taking your hand off could sent the router bit into the stock and that could jam the bit… many things could happen after that.
    Archtops, natec and mkdaws32 like this.
  7. Dano-caster
    Dano-caster Tele-Holic
    Snore'n desert
    Don't bite off more than you can chew.( How do I know?). Easy does it...Be careful my man...
    Frodebro and Archtops like this.
  8. trev333
    Coolum Beach,Australia
    full concentration and a solid grip..... rout with intent..... they are the scariest hand tools to use...
    I'm an experienced metal worker who has used all manner of big scary machines/tools.... and do carpentry with power saws, etc...
    routing gets my FULL attention....:eek::twisted::D
    Frodebro, ChicknPickn and Engine Swap like this.
  9. Engine Swap
    Engine Swap Tele-Afflicted
    Chicago
    I never used a router, but finally took the plunge because I needed to route a neck pocket a little deeper.
    If doing this, resist the urge to do it without support for the router. I made a quick jig and the job was a piece of cake.
    And +1 to not moving or lifting the router until it has completely stopped. I violated this rule and made a small gouge in the side of the neck pocket. Thankfully, it doesn't show with the neck installed.
    Timbresmith1 likes this.
  10. trev333
    I use a trimmer to do my pockets, I make a bigger base to use for more stability....
    my big 1/2" machine seems a bit over kill for pockets .
    Timbresmith1 and ChicknPickn like this.
  11. trev333
    a good set of Forstner bits to hog out most of the material before you even get your router out....;)
  12. oldunc
    oldunc Tele-Afflicted
    California
    Be careful about direction when edge routing, or following an outline. Bit on the right of the cut pulls it in to the cut; on the left it tends to bounce off. On the other hand, bit on the right (or pulling router toward you) is less likely to chip, so if you have a power stock feeder (guessing you don't- who does?) or are taking a very light cut, it can be the best way to go.
    televillian and Archtops like this.
  13. trev333
    think of a router as a vertical Planer and only try to shave as much material in a pass as you would with a hand Plane...or an electric planer for that matter...:D
  14. FuncleManson
    FuncleManson Tele-Meister
    Moline, IL
    Keep your fingers outta there. I learned that the hard way.
    Archtops likes this.
  15. tele_savales
    tele_savales Tele-Afflicted
    Brooklyn, Joey!
    I think this is one of those times where "pics or it didn't happen" does not apply.
    Frodebro and Dano-caster like this.
  16. Dan Miller
    Dan Miller Tele-Meister
    Thousand Islands, New York
    My mantra, whether it be power tool or hand tool(*), is "if it slips, where's it going to go?"
    First corollary is "If it feels unsafe, it is unsafe: time to back off and reconsider the job."
    * I've done more damage to myself with a utility knife than anything else. So far.
  17. FuncleManson
    Moline, IL
    Ahh... It doesn't look bad at all today.
    In 1997, I took off off the end of my left ring finger (my main bending finger!) on a router table at work. The nail was gone and it was shredded pretty good, but the ER doc did an amazing job sewin' it up and the nail eventually grew back. The finger's a little clubby and it's sensitive in cold weather, but it functions fine. If you look to the right of the nail, you can see a couple of the "spirally" scars.
  18. FuncleManson
    Moline, IL
    The only advice I can add to the tips others have offered is, don't get too comfortable. My accident occurred after I'd used routers and router tables for several years and I just got careless. I was actually a lot more careful when I was inexperienced.
  19. Willy-son
    Willy-son Tele-Meister
    NJ USA
    Sell the router and leave it to a professional.
  20. trev333
    slide 2 bearings onto the pattern bit shaft if you can, sits on the pattern better ,, :)
