Shape of neck pocket where it meets the upper side of the body
Discussion in 'Tele Home Depot' started by Yonatan, Apr 2, 2020.
  1. Yonatan
    Yonatan Tele-Meister
    Israel
    I'm definitely over thinking this, but it's hard to tell from the Tele body drawing, which way is it supposed to be?
    Some pictures I find online have the pocket jutting out from the body on the upper side by a bit i.e some of the body was cut out so that it doesn't come all the way to the end of the pocket:
    Some pictures I find show that on the upper side the body comes just about all the way up to the edge of the pocket:
    Those are the more pronounced examples I found, there are a lot in between.
  2. guitarbuilder
  3. Yonatan
    Israel
    To be clear, I'm talking about this part.
  4. RogerC
    RogerC Poster Extraordinaire
    Oklamerica
    Short answer -- Yes. That's how it's supposed to be.
    "But which way?" you ask.
    To which I answer, "Yes."
    If you've found examples of both ways pictured on Fender instruments, why would you think it's supposed to be one particular way?
    AAT65 likes this.
  5. Slowtwitch
    Slowtwitch Tele-Meister
    South Africa
    IOW You choose, it's your build :)
  6. guitarbuilder
    I'd give you the same answer as I made before. Don't sand off past the neck line of the neck pocket on either side. That's when it will look a little weird.
