SG thickness / SG Controls / Tele neck?
Discussion in 'Tele Home Depot' started by natec, Apr 21, 2021.
  1. natec
    natec Tele-Meister Silver Supporter
    Portland Oregon
    I'm considering building a thin-body (1-3/8") guitar with SG controls and humbuckers, but with a Tele bridge and neck.
    Considering the tele pocket needs to be 5/8" in order to line up properly with the bridge - will the 7/8" remaining body thickness be sufficient to secure the neck?
    crazydave911 likes this.
  2. Steve Holt
    Steve Holt Friend of Leo's
    Kansas
    I doubt you'll have a problem with it. Most Squiers are 1.5" so you're only talking about the difference of an 1/8". If that difference is make or break I'd be surprised.
    Just make sure that depth gives you enough to be able to route out all the cavities you need.
    crazydave911 and natec like this.
  3. guitarbuilder
    You should be fine depending on the wood you use. I'd choose something a little denser so the neck doesn't go flexing. That of course depends on where you put the neck joint. Set neck SG's can do some wiggling.
    Neck Flex | EverythingSG.com
    Maestro SG bodies with a bolt on neck are a bit thicker than a set neck SG. I think most Squiers are in the 1-5/8" ballpark, not 1-2/4, but I am not a Squier expert at all.
    This is a shot of a Guitar Fetish SG
    This is a Maestro by Gibson
    Maestro SG Junior | JB Photography | Reverb
    Epiphone SG Special Satin E1 Electric Guitar | Musician's Friend (musiciansfriend.com)
  4. bgmacaw
    bgmacaw Poster Extraordinaire
    Near Athens GA USA
    It should, at least using my Harmony H-801 as an example. The body thickness is 1.25" and the neck pocket is .75". The body is some sort of plywood I suppose. It's held up for about 50 years now.
  5. natec
    Portland Oregon
    Thanks all.
