Seymour Duncan Stag Mag for neck position in Tele?
Discussion in 'Just Pickups' started by Super Locrian, Oct 4, 2010.
  1. Super Locrian
    Super Locrian Tele-Meister
    Up North
    I love my Brian Monty Tele, but the Fralin P92 isn't working for me. I realize a lot of folks rave about it, but personally I find it lacking in character, and I play the bridge pickup (DiMarzio Area T) almost exclusively.
    I think part of what I'm after, is that "magnet in the coil" sound. This has led me to consider the Seymour Duncan Stag Mag, which has Alnico 2 rod pole pieces.
    Unfortunately, I haven't found any good clips or YouTube demos, so before I order one I'd like to hear reports from my esteemed TDPRI brethren. Do you use it in full humbucker mode, or mostly split? Is it too powerful with both coils active?
  2. Rich_S
    Rich_S Friend of Leo's Gold Supporter
    Potsdam, NY
    Man, I'd love to hear the answers to this.
    I suggest you also post this question over at the Duncan forum. The Stag Mag is fairly uncommon, and you're going to need all the help you can get.
  3. hwestman
    hwestman Tele-Holic
    Stockholm, Sweden
    or you could get a Rio Grande Tallboy humbucker...They are pretty easy to come by I think.
  4. Telenator
    Vermont
    The Stag Mag is a very cool pickup that offers serious clarity and bite like any rod magnet pickup. Wish I could help you with sound clips but I haven't seen any either.
  5. Tele295
    Tele295 Poster Extraordinaire
    Ventura CA
    I had one in the neck position of my SG years ago. Very cool sounding pickup. Through the right amp, it had that perfect "Wind Cries Mary" tone
  6. drf64
    drf64 Poster Extraordinaire Silver Supporter
    Ada, MI
    I had them in, of all things, an Ed Roman Baker. I sold it to buy a heritage 150, but the reason I had Stag Mags put in was to get authentic single coil sounds when split. I would recommend them for that reason, but I have no idea what they would sound like for a neck bucker in a tele. Hotter than typical PAF I imagine, but you do get a very nice SC sound when split.
    as an added plus they look kind of menacing!
    dan
  7. hwestman
    hwestman Tele-Holic
    Stockholm, Sweden
    A question to those in the know.... doesn't this kind of pickup induce serious string pull/stratitis with 12 magnetic polepieces in the neck position instead of 6?
  8. drf64
    Ada, MI
    It's been so long since I had it I can't answer specifically, but I know I did have to back it waaay down in the neck for a good tone. This is designed as a bridge pup.
    dan
  9. Pierce
    Pierce Tele-Holic
    skull island
    had them in a tele (remember the ampeg heavy stud?) I used it split and it sounded great.
    you might have to fuss with pickup height)
  10. Telenator
    Vermont
    The original Fender Wide Range Humbuckers had 12 magnets in them and there's no problem with strings pull. It's not the kind of pickup you set real high, close to the strings.
  11. jrfrond
    jrfrond Tele-Holic
    Long Island, NY
    Besides the Stag Mag and Rio Grande Tallboy, Tom Anderson humbuckers are also "Direct Magnet".
    I once made my own Stag Mag using A Dimarzio Super Distortion, removing the screw polepiece, drilling the holes out to 3/16" and inserting Alnico 5 magnet rods, cut to the right size, and using a full wood spacer under the coil forms. Still have it. Sounds great!
    mrz80 likes this.
  12. wfrcrd
    wfrcrd TDPRI Member
    Italy
    I have an old one and I'm thinkink to use it on a chip tele.
    I'd like to split phisically the two bobbins and use it one in the bridge position and the other one in the "middle" position ( in that tele i made an additional hole in the body, as a stratocaster) , with a standard strat 5 way switch + a push/pull pot to obtain the humbucking configuration.
    I have a lot of sigle coils pickup to use in the middle position but i suppose that the "other" bobbin of the stagmag should be magnet polarity inverted so i hope to get less hum when i use it with others.
    Here is the wiring diagram
    http://www.tdpri.com/forum/tele-technical/600511-need-help-tele-modified-wiring.html
    bye!
  13. JD0x0
    JD0x0 Poster Extraordinaire
    New York
    ALnico 2 magnets. One of the weakest grades. Even with A5 magnets, it'd be no worse than 2 tele or strat pickups.
    Another pickup worth looking into is the Lawrence Wilde L-600. Alnico 3 rod magnets, very clear sounding bucker. Not sure what the split sounds like, I'm waiting on mine, but I'm expecting good results. The L-90's split really well, IMO.
  14. Tele295
    Ventura CA
    I had one in the neck position of a Gibson SG. Great for that Hendrix-y Wind Cries Mary sound
