Seymour Duncan PU for tele
Discussion in 'Just Pickups' started by Craig Williams, Jan 18, 2021.
  1. Craig Williams
    Craig Williams Tele-Meister
    Thailand
    Hi all. I've got a sweet little Thinline (Classic Vibe). Absolute joy to play but PU a little week. On the spur of the moment I got offered some near new Pick ups at a really good price so I took the plunge and ordered them I play pretty much clean, just want a nice clean bitey smooth tone.
    Pick ups I got both Seymours. Bridge quarter pounder and neck SD Vintage (not stack)
    What could I expect from these pick ups / combination?
  2. kookaburra
    kookaburra Tele-Afflicted
    Phoenix, AZ, USA
    The QP is a pretty hot single coil. If it’s tapped, put it on a switch for vintage like and heavy sounds.
    If you’re strict about vintage, that may not do it for you, but otherwise you’ll find it useful.
    I have not used the neck model that you mention.
  3. JeffBlue
    JeffBlue Tele-Afflicted
    Southern California
    I'd use either a Seymour Duncan Five-Two or a Jerry Donahue.
    UPtele likes this.
  4. SnidelyWhiplash
    SnidelyWhiplash Friend of Leo's
    Hoggtown, KY.
    The Broadcaster is very good also.
  5. Jakedog
    Jakedog Telefied Ad Free Member
    The North Coast
    I love the QP. It’s only downside is that it’s still a single, so still noisy.
    My favorite SD for tele bridge position is the Hot Stack Lead.
    That neck pickup is a great representation of a vintage tele neck pickup. I like a neck single brighter and more strat like, but if you’re down with the vintage style tele thing you’ll probably dig it a lot.
    BB likes this.
  6. Milspec
    Milspec Poster Extraordinaire
    Nebraska
    The SD Vintage Broadcasters are probably what you want...very nice vintage toned pickups. Actually, one of my favorite telecaster have them and for the price they are outstanding.
    The Quarter Pounders I have also used and it does put out a lot of punch, but it doesn't sound like a vintage tele at all. Good for drive, but not the best for cleans.
    SnidelyWhiplash likes this.
  7. 65 Champ Amp
    65 Champ Amp Tele-Afflicted
    Illinois-Wisconsin line
    You’ve already made your choice.
    It doesn’t matter, you’ll get 47 suggestions for something different.
    You will know soon enough what you can expect, how about a review then?
    Marc Morfei likes this.
  8. hwestman
    hwestman Tele-Holic
    Stockholm, Sweden
    My experience of the vintage neck pickup is that it's pretty low output so the QP may be much louder unless you set it very low.
  9. YoGeorge
    YoGeorge Tele-Afflicted
    Michigan
    The QP bridge is very hot and middy and you will hopefully enjoy that. In comparison, the Duncan vintage neck pickup is weak and dull (dull due to the brass cover), and won't balance very well with a QP in the bridge. This is only important if you like consistent volume across your switch positions. I've used both of these pickups but never together. I hope they work for you.
  10. That Cal Webway
    That Cal Webway Friend of Leo's Silver Supporter
    Minot
    APII
    Rich tones
  11. Blues Twanger
    Blues Twanger Tele-Afflicted
    NYC and VT
    I like the Vintage neck but mine isn't in a Thinline. It pairs with a Broadcaster bridge in an Am Pro.
  12. DeepDangler
    DeepDangler Tele-Meister
    Mequon, WI
    The quarter pound is dark for a tele pickup and powerful. Seymour Duncan recommends 500k pots for them. You'll find your bridge sounds like a beefy P90 and the neck will be clean. I think you will have a fun pickup combination. The quarter pound has enough power and output that you can run it lower under the strings if you need to balance the output.
  13. Arfage
    Arfage Tele-Meister
    Alameda Ca
    I'm just putting the same set in today, except I got the tapped 1/4 lb. bridge. I'm expecting good results and, I got the tapped bridge. This gives me a new thing to do with the 4-way switch that's already in it. (1) full power bridge (2) tapped (3) tapped and neck in series (4) neck. I'm going with the series because before, after getting an earful of that I never used the regular two pickup position again. And the full power 1/4 lb. in parallel with vintage pickups works nicely; I know because I had a strat with the 1/4 lb. bridge and two vintage.
  14. teleplayr
    teleplayr Tele-Afflicted
    Nicoma Park, Oklahoma
    I have a Duncan "Vintage" in the neck position & a "Vintage Stack" for the bridge in my MIJ Custom Telecaster w/Bigsby.
    Great clean sound esp. on the neck pick-up. The bridge pick-ups wired not to split, but noise cancelling.
