Seymour Duncan Antiquity in Neck position
Discussion in 'Just Pickups' started by whetherkings, Jun 14, 2021.
  1. whetherkings
    whetherkings TDPRI Member
    I currently have a Fender Wide Range pickup in the neck of one of my Teles.
    I’m considering swapping it out for a Seymour Duncan Antiquity neck pickup.
    Question is - do I go with the humbucker or mini humbucker?
    And is there a significant difference between Antiquity I and Antiquity II?
  2. teleplayr
    teleplayr Tele-Afflicted
    Nicoma Park, Oklahoma
    Email the folks at Duncan, they're good about responding.
    Fretting out and SnidelyWhiplash like this.
  3. whetherkings
    Thanks - I understand the technical differences, I was asking more in terms of what other people have decided after using them in their own guitars and with different setups.
  4. hamerfan
    hamerfan Tele-Meister
    Germany, Bavaria
    Full size Humbuckers tend to be very wooly sounding if paired with a single coil in the bridge. Mini hums tend to go along better.
    Clifton C and richiek65 like this.
  5. whetherkings
    Yes - even with 500k pots the wide range just sounds too dark. So I’ve been considering switching to a regular sized humbucker but I’m also wondering if a mini humbucker might be better or even a firebird. Maybe I should just build three identical guitars with all options…
    Clifton C likes this.
  6. Mad Kiwi
    Mad Kiwi Friend of Leo's
    Land of the Long White Cloud
    Appreciate the advice here but how does Keith Richards get on with his humbucker in the neck, it is a humbucker isn't it?
  7. carpenter
    carpenter Tele-Afflicted Silver Supporter
    Naugatuck, Connecticut
    Seymour Duncan , the moto at the custom shop is they will wind them anyway you want them. Choose your magnets too.
  8. hamerfan
    Germany, Bavaria
    Keef uses no Low E string, because this is the one which is droning badly on hummers.
  9. whetherkings
    Just realised that the wide range I have must be REALLY dark because the pots are 1meg and they’re not doing anything to brighten it up! I have resolved to try both the Seymour Duncan Antiquity Humbucker and mini Humbucker to see which I like best.
  10. loudboy
    loudboy Tele-Meister
    Sedona, Arizona
    I have one in my Tele and it's too dark.
  11. whetherkings
    Definitely going to offload the wide range. But will need to try the Seymour Duncan with 500k and 1meg pots in case the 1meg is too bright.
  12. DisharmonicDark99
    DisharmonicDark99 TDPRI Member
    Midwestern U.S.A
    Obviously depends on your own style and ear but I once switched out a Wide Range for an Antiquity I and I really liked the results. It was darker than the Wide Range but I welcomed it.
    Regarding the differences between the two Antiquities....they definitely do have a significant difference to them, at least to my ears. The Antiquity I is a bit warmer and has a smoother top-end to it, the Alnico 2 magnet likely being a major factor in that. It still chimes but the treble end just has a bit more of a smooth rolled-off quality to it. The Antiquity II has a little more chime and top-end sparkle to it and works better I think for if you want that surf guitar kind of tone from it. So I do think the tone of the pickups are definitely different from one another, but not a night-and-day kind of difference. If you wanted something a bit more warm and subtle I'd say go with the Antiquity I.
    whetherkings likes this.
  13. whetherkings
    I’ve decided to just try all of the options - so I’ve ordered a mini to test and I’ve just finished installing the regularly sized humbucker into a body. I’ll end up with three or four options in identical guitars to play side by side to see which I like best. Then I’ll be left with a couple of guitars to sell.
    DisharmonicDark99 likes this.
  14. rigatele
    rigatele Tele-Afflicted
    Are the controls 250k?
  15. adjason
    adjason Poster Extraordinaire Silver Supporter
    virginia
    Every picture I see of Keef has him playing the tele bridge pickup...of course I am no expert. I like the idea of a firebird neck pickup
  16. Clifton C
    Clifton C Tele-Afflicted
    Houston
    I have a Gibson mini-humbucker in the neck position of my avatar guitar, and love it! It’s great at getting bluesy and jazzy sounds, but then there’s still the bridge pickup for Tele sounds. I like it so much I’ll probably get one for my 50s American Original Tele.
  17. loudboy
    Sedona, Arizona
    500k, bridge is a Bill Lawrence 48-TL.
    It sounds fabulous in the middle position.
  18. backalleyblues
    backalleyblues Friend of Leo's
    Jacksonville, FL, USA
    I’m having the same problem as well-original WRHB in the neck is just too dark for my tastes-I have a late 70’s Gibson humbucker in another Telly that’s almost identical, and that one has a nice brightness to it that I like-actually thinking about a plain old 490r as a replacement (I have one in my 2017 LP tribute). Bridge pup in my case is a Dimarzio area hot t, which is quite nice actually...
    Franc Robert
  19. hamerfan
    Germany, Bavaria
    Are you in using a 1 meg vol pot? This is what Fender used.
