Serious treble attenuation with RobRob PPI MV. Is that your Experience?
Discussion in 'Shock Brother's DIY Amps' started by randomhitz, Feb 15, 2021.
  1. randomhitz
    randomhitz Tele-Meister
    Missoula, MT
    Did I screw up somehow? Pretty simple mod. Seems like it's creating a filter.
  2. Tom Kamphuys
    Tom Kamphuys Tele-Holic
    The Netherlands
    What amp? Schematic?
  3. randomhitz
    Missoula, MT
  4. D'tar
    D'tar Friend of Leo's
    WNY
    Photos?
  5. Mexitele Blues
    Mexitele Blues Tele-Afflicted
    Westminster, CO
    I've always wondered, does PPI stand for pre-phase inverter or post-phase inverter?
  6. XTRXTR
    XTRXTR TDPRI Member
    Northern Colorado
    Also did you mod a Pre PI MV or a Post PI MV? "PPI MV" doesn't fully describe which mod you did. As others have said Photos and Schematic.
  7. Paul G.
    Paul G. Friend of Leo's
    Rhode Island
    I have this on my 5E3. No, it doesn't effect the tone at all when turned down. Double-check all your work.
  8. David C
    David C Tele-Meister
    Coraopolis, PA
    I don't have any impact with treble attenuation with the master volume on my 5E3.
  9. randomhitz
    Missoula, MT
    Thanks for all your replies. Got it working properly. I'll school myself on how to post images. Seems like the only difference this time around was I had the proper I meg audio taper pot. Previously I was using a linear taper 1 meg while I was waiting for the audio one to arrive. I assumed the only difference would be which section of the travel would have the biggest effect.
  10. dan40
    dan40 Friend of Leo's
    Richmond Va
    The pot taper should have no affect on the amps brightness. It may be that during the pot replacement you inadvertently fixed a bad solder joint.
    RollingBender, King Fan and D'tar like this.
