Serious issue with a ‘70 fender dual showman reberb
Discussion in 'Amp Tech Center' started by Jeremyhasaproblem, Sep 4, 2020.
  1. Jeremyhasaproblem
    Jeremyhasaproblem TDPRI Member
    Conmecticut
    The amp works and sounds great, but after 3-4 minutes of playing it starts shocking the player through the strings of the guitar(and only in this manner). None of the cords, connectors, switches, pots or jacks exhibit that quality(they don’t shock you). I can do basic electrical soldering and simple electrical work, but would like to see if someone more experienced has any idea why something like this would happen? Especially since this amp has a ground in the cord and also in the circutry.
  2. Fretting out
    Land of Mary
    Is it all guitars or just one?
  3. stantheman
    stantheman Doctor of Teleocity
    White Mountains
    Just a hunch - it sounds like the guitar ground solder broke apart. Someone else will know for sure.
  4. Jeremyhasaproblem
    Conmecticut
    It does this on all guitars that i plug in, but the guitars i have all have passive pickups(no idea if that matters at all). I should also mention a have a second dual showman reverb(i think it’s a ‘68) that i can potentially scavenge parts off of if i have to. That amp does not shock the user, but it also makes no sound.
  5. Jeremyhasaproblem
    Conmecticut
    I will try to post a picture of the board in a couple minutes, my phone is being stupid at the moment.
  6. Jeremyhasaproblem
    Conmecticut
    is there any way that this switch would matter in that way?
    Also, i may be the dumbest person alive...
  7. Jeremyhasaproblem
    Conmecticut
    backside of the amp w/cover removed.
  8. Jeremyhasaproblem
    Conmecticut
  9. Jeremyhasaproblem
    Conmecticut
    Okay it’s clearly going to take a while to get the board out, somebody was messing around with this thing before and they were rather messy about it.
  10. Jeremyhasaproblem
    Conmecticut
    pics of the “circut board” , to me it just looks dirty and like it has been sloppily repaired, but you guys definitely would know better than me. I hope one of you can see something that doesn’t look quite right to you so that i can address it. As i said i can do basic electrical work but know very little about these specific amplifiers other than the fact that they sound incredible.
  11. Fretting out
    Land of Mary
    Honestly I have no idea about amps, I was thinking something simple may have happened, maybe the guitars bridge wasn’t grounded
    Since it’s happening on more than one guitar that should rule that out
  12. Jeremyhasaproblem
    Conmecticut
  13. glenlivet
    glenlivet Tele-Holic
    Marco.......Polo......
    I'm no expert on that particular amp (or anything else really)...but that sure looks like 2 wire power to me?
    If your plug has 3 prongs on it....then somebody spliced the cord (and left the ground unconnected).
    I could be way off base, but it looks to me like you have no chassis ground.
    Wally, BobbyZ, nathan5782 and 2 others like this.
  14. tubegeek
    tubegeek Friend of Leo's
    Brooklyn, NY
    Does the amp have a 3-prong cord or only 2?
    hepular likes this.
  15. brown2bob
    brown2bob TDPRI Member
    Tampa, FL
    I only see two wires on what appears to be the power input. This would support that the amp is not really earth grounded. There should be three wires, white=neutral, black=hot, and green=chassis ground.
    hepular likes this.
  16. Jeremyhasaproblem
    Conmecticut
    Yes it is a 3 prong, yes it is spliced after the board. My apologies i could have sworn this was the one that we added a ground at the board to, it must be the ‘68 we erroneously added a “chassis ground” to. I’ll have to clip and redo this one properly. Thank you so much.
    zook and hepular like this.
  17. tubegeek
    Brooklyn, NY
    Be safe. Rock on.
    hepular likes this.
  18. hepular
    hepular Tele-Meister
    abilene, tx
    So, in a case like this, what would be the best procedure? drill a hole in the chassis & star-fangle washer, sheet-metal-screw & solder the ground wire or ground to that transformer bolt? or just wrassle the 100w iron in and solder to chassis?
  19. tubegeek
    Brooklyn, NY
    For ground: dedicated bolt with lock washer, with a crimped-on ring terminal to the green wire. Ground wire longer than (more slack than) neutral and hot. Go in through the original hole, if possible, and use a standard D shape grommet to strain-relieve the cord. This is why we salvage 3 wire cords & D grommets from stuff people throw out!
    Soldering to the chassis is SO last century!
    Junior Little, hepular and glenlivet like this.
  20. BobbyZ
    BobbyZ Doctor of Teleocity
    Snellman MN
    The guitar's "ground" is the amp's chassis "ground". The shield in the instrument cable ties those together. I used "ground" because sometimes there's voltage on the chassis.
    That's why a properly installed grounded cord plugged into a properly wired outlet is such a nice thing to have.
    Ebidis likes this.
