Serious brain fart
Discussion in 'Amp Tech Center' started by ce24, Mar 31, 2020.
  1. ce24
    ce24 Poster Extraordinaire
    Idahoastan
    Well...i was rolling tubes in my homebrew vibrio champ......put a JJ6v6S into the rectifier socket. Of course nothing turned on...cept now that i have the correct tubes in the right spot it wont turn on.....fuse good.....no smoke. No pilot light.
    HELP!
    thanks and cheers
  2. galaxiex
    galaxiex Tele-Afflicted
    Edmonton, Alberta Canada
    My guess...
    Power Tx has an internal fuse.
    It’s blown.
    ce24 likes this.
  3. ce24
    Idahoastan
    Thanks ill check it out.....
  4. ce24
    Idahoastan
    IMG_20200331_171903855.jpg here is the tranny...a Weber.. Not sure how to test it to see if it's blown. Have multimeter....
  5. galaxiex
    First, UNPLUG AMP FROM WALL OUTLET.
    You will want to test for ohms and/or continuity on the primary winding of the Tx.
    This could be done thru the power cord IF you are certain how the cord is wired.
    Power switch would need to be "On".
    OR, disconnect primary Tx wires and connect multi-meter probes to those primary wires.
    The actual reading is not so important, we are just testing to see if there is continuity in the primary winding.
    No continuity, then likely there is a hidden internal fuse in the Tx that has blown.
    Sometimes they are replaceable, sometimes not.
    Could call Weber and ask if that Tx has a fuse....
    ce24 and D'tar like this.
  6. ce24
    Idahoastan
    Thanks for your response.....all the windings have continuity....so I just checked the fuse for continuity,and who woulda thunk, it was dead....apparently the slow blow windings look ok with no blown gaps. Buuuttttt nooooo when it's blown it still looks good. So...I learned something useful today and that's a tough thing when your 69.lol. thanks again galaxiex!
    Cheers
    Ce24
    D'tar and galaxiex like this.
  7. galaxiex
    Glad you found it. :)
    sjoko and ce24 like this.
