i was lucky enough to pick up a TS-9 reissue that the owner said wasn’t working. I got the switch to work and cleaned the pots and I love the pedal. However, the top left corner of the PCB is broken off where there should be a hole for the single screw that holds it in place. Looks like they had tried to solder the screw head to the bit of board that it still held, but now the board and AC jack move when I plug a power cord into it. Has anyone come up with a way to secure a board like this, without permanently gluing it to the enclosure? I’ve read posts about Goop or sealant along the sides. I though maybe I could solder or glue a washer over the broken corner, to screw through. I’ve got some epoxy that I use to try to rebuild the corner, and drill through? Right now it’s being held by electrical tape! Thanks in advance for any tips or suggestions.
