"Secrets of Sustain: Why Pickup Position Matters", article by Craig Anderton
Discussion in 'Just Pickups' started by EsquireBoy, Feb 26, 2020.
  1. EsquireBoy
    EsquireBoy Tele-Afflicted
    Paris, France
  2. brookdalebill
    Austin, Tx
    Indeed interesting, thanks!
    EsquireBoy likes this.
  3. tah1962
    tah1962 Tele-Holic
    Heart of Illinois
    I know a lot of people that were ready to swap pickups until I recommended adjusting their pickup heights. I think this is one area that many people definitely overlook. They assume that the factory setup is the holy grail. The first thing I do when buying a used, or new guitar is to give it a complete set up, including setting the pickup heights to my taste.
    gwjensen, bftfender and EsquireBoy like this.
  4. Old Deaf Roadie
    Old Deaf Roadie Tele-Afflicted Silver Supporter
    Oregon
    Craig Anderton is always a good read.
    BB and EsquireBoy like this.
  5. bftfender
    bftfender Friend of Leo's
    York PA
    absolutely agree..it usually takes me a few months to slowly set my guitar up...after some hours & familiarity..i look to see what role it will play in the tonal spectrum. Have a screwdriver right at my main practice spot...mess with them pickups...it takes some experimenting..but you truly can get all positions functioning top notch & then the blend can be the most amazing sound of both combined...so much is available in the adjustments...the set up ..is always ongoing..
  6. Whatizitman
    Whatizitman Friend of Leo's
    WV
    This is new ground for me - timely. I've been tweaking the pickup height on my new p90 guitar a bunch. So much that I keep a small flat head and phillips next to me.
    I'm finding it's a challenge to get enough sustain on the high E (both bridge and neck), but still have enough room for the string to keep from hitting the poles when fretted/plucked. I know the frets need a little loving, so that could be part of the issue. But still. Sheesh. As soon as I think I got it, I come back later and it still doesn't seem right.
    Feels like more art than science. :eek:
    EsquireBoy and gwjensen like this.
  7. Antigua Tele
    Antigua Tele Friend of Leo's
    west coast
    I did this same experiment https://guitarnuts2.proboards.com/thread/7998/tonal-effect-pickup-height and some others too, though I was using a Strat with three A5 single coils and not humbuckers. The decay rate was virtually identical regardless of pickup height once amplitude was normalized.
    The bigger impact is on how the string oscillates, because as they magnetic pull increases, the string becomes an increasingly asymmetrical systems, and it's easy to see, each sample has the pickup set increasingly closer to the string, using the neck pickup, mechanically plucking the B string:
    Note that these are long decays too, fifteen seconds each. The issue if pickup height and sustain goes from little to nothing when you consider how rare it is to hold a chord for fifteen seconds.
    This issue doesn't apply to Telecasters too much either way, because pickups near the bridge affect the strings less than pickups near the bridge, because the strings are stiffer towards the ends. So just taking the neck pickup into consideration, a Tele single coil neck pickup has an especially insignificant pull upon the strings compared to either a Strat or an HH guitar, especially if the neck pickup has AlNiCo 2 or 3 pole pieces, and the flat stagger keeps the magnets further away from the centermost strings.
    TimTam and EsquireBoy like this.
  8. EsquireBoy
    Paris, France
    That was really interesting to read, especially about the harmonic content. Thoughts for food... Thanks for posting!
  9. Teleguy61
    Teleguy61 Friend of Leo's
    Eastern Massachusetts
    I have found Bill Lawrence's suggestion--the real Bill Lawrence, Willi Stich--that a nickel under the string on the high E, set the pickup to just touch string and pickup, low E lower, is a good starting point.
    I have a light touch, so I tend to like the pickups close to the strings to get the sound I want. Just my $.02.
    Dan German and EsquireBoy like this.
